Front speaker size?
Old 01-01-2010, 11:59 PM
jadiehr's Avatar
Front speaker size?
I noticed it was posted that the rear speaker size for a 2001 is 5.25" and a 6.5" speaker will work. I was wondering if anyone knows what the front speaker size is? Thanks in advance.
Old 01-02-2010, 01:21 AM
XJJoe01's Avatar
In my 02, I replaced the speakers all the way around and noticed a 6x9s will fit. I installed 6 1/4 with an adapter plate based on Crutchfields advice.
Joe
Old 01-02-2010, 01:27 AM
6speedcowboy's Avatar
Joe
put 6x9's in my truck too. gonna re-do the system here pretty soon and replace the 6x9's with round speakers. you get alot better sound clarity from the round speakers over ovals
Old 02-22-2010, 08:52 PM
1dumrednek's Avatar
will 6x9s fit only in the front or do they work in the back doors too?
Old 02-22-2010, 09:46 PM
kreynolds's Avatar
6x9s will not fit in the rear doors. The speaker hole is round.
Old 02-23-2010, 10:49 PM
The Guru
Mike Holmen's Avatar
I tried to put 6X9 in my truck and the door window rail interferred with the speaker magnet. The 6 1/2in speakers fit with the adapter. Depends on speakers. You could fit them into the quad door, you just need to do some trimming on the door. I run two 6 1/2 speaker per door.
Old 02-25-2010, 09:57 PM
1dumrednek's Avatar
ya i had my door panels off yesterday and saw the round ones. i noticed theres two round holes in the back doors. is that what you meant by two speakers in each door Mike?
Old 02-26-2010, 08:08 AM
The Guru
Yup, I put in two 6 1/2in speakers in there, in my truck. I have to find some different door panels so I can do some trimming on the panel. I run two 400X2 amps for each speakers and a 600X2 amp for the front door. The front door is abit more tricky, as there is moving window parts. You could fit in a 6X9 into the door, but the magnet hits the window, of course it depends on which speaker you use. I run a 1200X2 sub amp for my dual 12in subs, the set-up works nice, but doesn't have that big thump sound, as I use shallow 12in subs. I run four tweaters, two in the doors and two in pillars posts.
It works pretty nice, I just have to finish my deck install one day, I bought one of those fancy alpine units that has everything like ipod, bluetooth, siruis, CD unit controller. Lots of little boxes to be hooked up. I put everything behind the rear seat.
I also put in tons of sounds deader, in the floor, doors, dash. You can actually talking and hear someone inside the truck now.
Old 03-20-2010, 10:23 PM
cowboyjay's Avatar
Check out amazon.com..I got some great Rockford Fosgate 6x9's..they sound great!
blackdiesel
12-09-2006 08:33 AM
scoutman
08-16-2006 09:35 PM
Sloverado
08-08-2006 11:37 AM
Patrick Campbell
12-16-2004 01:53 PM
99DodgeGuy
10-08-2004 07:40 PM
Quick Reply: Front speaker size?
