Front end vibration???????
Hey guys,
I have a vibration that comes and goes in the front end. Usually I would point to the wheel bearing as the culprit but just doesn't seem like the issue. The problem is very intermitent. Doesn't even happen everytime I drive the truck. The truck will be fine until I hit a good bump and then I will get a vibration that I can feel in the steering wheel and under my feet. It is definitly rotational. The really strange thing is when I engage the 4 wheel drive the vibration goes away. I am going to change the front diff fluid and see if that makes a difference.
Is it possible the axle bearing is going bad?
Thank you
Thank you
no probably not type in death wobble in the search engen here and check your center-link . You should also check your steering box/frame mounts for crackes
Its not death wobble thats for sure. Its not a shake its just a rotational vibration. Its almost like the sound and feeling of having really knobby tires. Hard to explain, but nothing I have felt before.
No I don't have manual hubs... Would be nice though haha. I will disconnect the front driveshaft and see if it still happens tomorrow.
Thank you for the input keep it coming please...
Gordonville
04-18-2005 09:45 AM
BigBlue
05-11-2004 04:59 PM
Commatoze
11-21-2003 07:55 PM
bcb1962
06-24-2003 10:16 PM
