Front End Rattle
Old 10-10-2005, 07:59 AM
12PACK's Avatar
Front End Rattle
I've got a front end rattle on my 05, and it isn't the kind we all love. It sounds like a rattling chain, or a dogs choke collar shaking. It's not constant, doesn't happen at idle, and only when moving 15 mph or more. I don't think it's coming from the Cummins, as the only time I'll hear it related to engine sound (didn't want to say "noise") is when stopped and I bring it up to 1700 rpms. I'm guessing the vibration of the Cummins is what will cause it then. No leaks and nothing visible I could see.
The sound isn't consistant and hitting bumps doesn't change it. It doesn't sound like a loose shock, but more like a bad ujoint. That type of metal sound. I haven't been on the highway since noticing it, so I'm not sure if it does it in 5th or 6th, but will do it in the other four gears, i.e. not tranny related.
Any ideas? I've got an appointment with a local dealer tomorrow. Hopefully it's something minor as the less a dealer touches my truck, the happier I'll be.
TIA.
Old 10-10-2005, 04:47 PM
ftltmp's Avatar
If you can hear it while setting still I would say that it would more than likely be engine related. I would take the intake apart and look at the blades on the turbo and see if they are hitting anywhere, like a bearing or somthing went bad. Just my .02 . The only other thing I can think that might make the sound you describe is a idler tension pullley, maybe the spring went south.
Old 10-10-2005, 09:11 PM
12PACK's Avatar
I did hear something the other morning, that sounded like the blades were hitting something. I thought it sucked in a small animal. It stopped, and I was less than a mile from work, so I opened the hood with it running and everything seemed normal.
I took a good look at the serpentine and pulley and that looked fine, too. That's the first thing I thought of, as Britt and Wexman had issues with that.
Since it's new, I called a local dealer and it's there now. I'll update this as soon as I hear something.
Old 10-11-2005, 06:36 PM
OilBrn's Avatar
I put some nerf bars on that required loosening the rubber
cab mounts, now the friggen truck squeaks when going thru my yard.I traced it down to the right rear one, I put some lube on it, and it stopped for a couple days, but now it squeaks again, it's driven me nuts.
Old 10-11-2005, 08:07 PM
12PACK's Avatar
Dropped the truck off yesterday and didn't hear anything today by 4 pm, so I called. They couldn't hear the noise. Surprise, surprise. They want me to go for a ride with one of their techs and point it out.
"They did notice a bracket for the fan shroud was broken so we ordered one for it. It will be here tomorrow if you want it fixed then" the service writer said.
Did they think the noise might be coming from a shroud that wasn't secured? Apparently not.
This would certainly explain why it wouldn't do it while stopped unless the engine was brought up to 1700 rpms.
I'll be picking it up tommor after work. I'm using my mom-in-laws Subaru. Peppy little thing, but talk about a moving crumple zone. Maybe it's just me, but more people have been pulling out in front of me since I picked it up.
Old 10-12-2005, 08:56 PM
12PACK's Avatar
I picked up the mighty Cummins after their service dept closed so I couldn't talk to anyone. I called earlier in the day and asked them to lock my keys and the receipt in the truck, which they did.
As I posted, they found the fan support bracket broken. Here's what they replaced: one support F 9043003 and one coolant C 1081004 covered under warranty.
I couldn't hear the noise on the way home so hopefully, that's what was causing the noise.
Old 10-12-2005, 09:18 PM
ftltmp's Avatar
I am glad it was not anything major.
Old 03-30-2006, 07:35 PM
rickkari0304's Avatar
I had/have a similar symptom. The dealer called today and said it was some type of tensioner. I only really notice it at idle. Does this sound like the culprit? I thought it was internal to the engine. Thanks.
Old 03-30-2006, 07:42 PM
texaspower19's Avatar
i once sucked in a rat into my turbo on an 04 ford. i cleaned my intake one night , one cold night. left it out all night to dry, next morning i slaped it on and got about half way down the drive way and the truck died . pulled the filer of and saw fur every were . looked down the hose and saw a tial. it didnt go through , but just got tangled up in the fins.
Old 03-30-2006, 07:56 PM
12PACK's Avatar
Here are a few threads you might want to read:
https://www.dieseltruckresource.com/...ight=tensioner
https://www.dieseltruckresource.com/...ghlight=pulley
You might be the first 06 owner to have this. On this site anyway.
Old 03-30-2006, 08:09 PM
Raspy's Avatar
It's not you! It happens all the time to me when driving my Passat instead of my Dodge. Sheesh.
Wetspirit
Old 03-30-2006, 09:13 PM
12PACK's Avatar
Do you find yourself looking at vehicles coming towards you and saying to yourself "Boy, if he crossed the solid line and hit me head on I'd be dead."
Doesn't happen when I'm in the wife's Volvo, but the infrequent times I'm in anything else it does.
Old 03-30-2006, 10:28 PM
Every morning when I first start the truck I hear a screech or squeal coming from the fan somewhere. Stops after I drive it at all. Before the dealer fried my PCM, they were supposed to fix it. They replaced the FCM, front control module which was causing my reverse lights not to work. Reverse lights were fixed but noise on start-up still there. Hopefully this takes care of it. This is day 24 in the shop since early Feb. If this doesn't fix my issues I will look at the Lemon Law. Chrysler did make my truck payment though. I give them props for that. Later.
Old 04-11-2006, 12:27 AM
Noises still there. I need a good mechanic in the Seattle area. Anyone know where?
Geico266
07-01-2005 04:12 PM
Cummins600
05-19-2005 10:44 PM
capt.Ron
16
10-25-2004 10:17 PM
capt.Ron
09-02-2004 08:33 PM
Quick Reply: Front End Rattle
