Front coil spring replacement
Old 03-06-2009, 09:13 AM
ric o'shea's Avatar
I have been deciding what to do about the bottoming out of my truck. I replaced the track bar with a thuren adjustable. As far as I can tell it's installed correctely but the frame end mounting bolt scrapes the differential cover when the front end dips from a bump.
I guess the coils are weak? I was thinking about installing new coils from coil spring speacialties that are 2" longer. At the same time I see those metal leveling spacers and wonder if that is the way to go. I would also be installing new bilsteins up front at the same time.
Any input? Thanks..
Old 03-06-2009, 07:55 PM
Kansascrewcab76's Avatar
See my "048" spring post below, personally I wouldn't go with the spacers, because it doesn't solve the real problem-inadequate springs. If you add spacers you are just lifting the truck back up, new coils properly support the load and give a better ride
Just my .02
Old 03-06-2009, 08:02 PM
Danderson's Avatar
Thuren.
Call Thuren and ask his opinion. He'll recommend his or Carli's depending on your application.
Old 03-07-2009, 07:11 AM
smokinram99's Avatar
you should better go with new coils in my opinion; if your coils are sag, adding a spacer cant solve your problem, you 'll have sag coils w a spacer nothing better. you can look at Skyjacker D25, KORE leveling COILs+shocks, Lorenz Ind. http://lorenzindustries.com/index.html, Carli or CSS
rob
Old 03-07-2009, 04:14 PM
MSquare's Avatar
I went with custom springs from Coil Spring Specialties. IMHO they look way better then the D25's and the ride is to my specs.
Old 03-07-2009, 04:16 PM
Doj Dewd's Avatar
the springs in my sig have been GREAT . . .
Old 03-07-2009, 07:39 PM
Crazydave's Avatar
I put in D25's, I'm sure there are better springs but these were priced right and a lot cheaper the springs from the dealer. I plow snow and didn't have a plow prep package and killed the stockers I think they were 038 037. So far the skyjackers are holding up well to the weight.
Old 03-08-2009, 01:36 PM
ric o'shea's Avatar
Thanks everyone for your help. I thought the same about spacers not fixing the problem but wanted to ask those who had replaced weak springs just to be sure.
Now with this info I will look into which springs to get and prices.
Old 03-08-2009, 03:33 PM
kennyblatz's Avatar
i went with a carli starter kit and wow the thing rides so much better i have never once regret spending the money one of the best mods forsure.
Old 03-09-2009, 12:08 PM
ric o'shea's Avatar
Any good places to order online bilstein's shocks from?
Old 03-09-2009, 05:47 PM
If you read my post like I suggested, you'd know. Geno's has a special going on 225 plus shipping.
Old 03-10-2009, 02:37 AM
ric o'shea's Avatar
Did not see a geno's shock special anywhere in this thread.https://www.dieseltruckresource.com/...d.php?t=235301
Maybe I'm missing something.
flynhigh205
02-26-2008 10:33 AM
justagoodolboy
12-26-2006 08:09 PM
Igor
12-19-2006 10:04 AM
Flashman
13
09-22-2006 03:48 PM
Den
01-19-2005 04:27 PM
Quick Reply: Front coil spring replacement
