PDA
View Full Version : Front axle queston
DetR6oit
10-20-2002, 10:02 PM
I have a 94 ram 2500 diesel. It has a D60 front axle right? How many splines do the axle shafts have?
yomitch
10-20-2002, 10:43 PM
where are you from, Deeetroit?
Superduty12v
10-20-2002, 10:56 PM
Yes. The 94 had a Dana 60 9-3/4" front axle. The axles are 30 Spline, 1.31" diameter (inner) 1.34" (outer).
DetR6oit
10-21-2002, 01:21 AM
<br>where are you from, Deeetroit?<br><br><br>I am from Warren MI actually, which is the first city north of Detroit. Guess I should put that in my profile huh ;D
DetR6oit
10-21-2002, 01:24 AM
<br>Yes. The 94 had a Dana 60 9-3/4&quot; front axle. The axles are 30 Spline, 1.31&quot; diameter (inner) 1.34&quot; (outer).<br><br><br><br>Are there 35 spline fronts? Did any Dodge trucks come with 35 spline rear D60s or is 35 spline mostly an aftermarket thing? Are 35 spline shafts pretty much a direct replacement besides needing a new carrier?<br><br><br>Thanks,<br><br>Matt
Superduty12v
10-21-2002, 01:37 AM
To use 35 spline axles you'll need a new carrier to match them. I don't know of any 35 spline D60 axles that came on the front of a dodge.
yomitch
10-21-2002, 11:30 PM
used to live in livonia mich and windsor ont during the 80s, worked as an electrician in a stamping plant untill 90 when everyone got laid off. moved to british columbia and still loving it out here. Check out pic on daulies2 page 3 where I live now.
