front axle noise
Old 11-26-2009, 10:25 PM
bobs05's Avatar
front axle noise
I have a problem in the front end of my 05 2500. It started about 2 weeks ago with a slight 2 or 3 second grind every couple of days. There was no consistency to the noise, any speed, hot or cold, etc. Then one day it got progressively worse, constant and louder. By the time I got home the noise was unbearable,and got louder if I turned to the left. I parked it until this morning, and then jacked up both sides, and isolated the noise to the passenger side. Pulled the wheel, caliper and pads and still had the noise.(There went the easy fix) There sounds like there is metal between the dust shield and rotor, but was unable to get the caliper bracket off(will try again in a.m.), but I also notice a lot of free play where the axle shaft comes out of the housing. Does anyone have any ideas, or even a link to a schematic for this problem. The truck is stock height with 285/70-17's
Thanks for any help and hope all had a good Thanksgiving
Old 11-26-2009, 11:09 PM
midwestdually's Avatar
most likely a wheel bearing.. the front axle will have play to some extent coming out of the axle shaft... have you seen if there was any play in the u-joint as well?
Old 11-27-2009, 09:58 PM
Pikeman's Avatar
Prolly an axle U-joint. Have replaced three on mine so far. Could be a wheel bearing but my shop here told me they are not known to go out nearly as often as the U-joints. I thought I had a bad wheel bearing when i took it in but turned out to be just a joint.
Old 11-29-2009, 08:03 AM
bobs05's Avatar
took it apart, and it is definitely the wheel bearing. thanks for any input
rustydeeretech
17
05-21-2011 03:05 PM
olskooldodge
12-19-2009 06:04 PM
JMZ
12-01-2008 08:28 PM
AndyS
05-07-2008 04:56 PM
mjsandt
15
08-28-2007 09:36 PM
Quick Reply: front axle noise
