Front axle disconnect
Old 04-10-2007, 08:47 PM
jimk403's Avatar
I noticed something about my axle disconnect, it doesn't. At least not in the garage with the engine off and no tires. Turn the pass side hub by hand and the drivesahft turns. The purpose of the disco is to disengage the front driveline, is it not?
If this thing is vacuum operated, is vacuum required to engage it or disengage?
Perhaps this explains my crappy mileage, 13.5 mpg avg hand calculated.
Any idea where I should start troubleshooting?
Thanks.
Old 04-11-2007, 02:12 AM
Big Smoky's Avatar
I'd go with either the posi loc cable to engage and disengage manually. Or do manual locking hubs. I had the CAD!
Old 04-11-2007, 06:13 PM
phox_mulder's Avatar
Having a non Cad truck, I'm not sure, but I think vacuum both engages and disengages it.
phox
Old 04-11-2007, 09:54 PM
BRET LIVELY's Avatar
Vacuum Moves It
The Needs To Be Running
Old 04-12-2007, 04:31 PM
zulusafari's Avatar
Does it disengage/engage everytime the key is turned off? Therefore, it requires vacuum to remain disengaged? I am also having lower than expected mileage. Perhaps mine is stuck, too? But wouldn't the front end buck during tight turns on dry pavement, like when I have the T-case engaged in 4x4??
Old 04-13-2007, 07:19 PM
mrclean's Avatar
No, it does not. There are two vac hoses on the CAD. When you shift to 4WD, vacuum is supplied to one of the vac lines, engaging the CAD. It will stay engaged until you shift to 2WD, vacuum is supplied to the other hose, disconnecting the CAD. The vacuum actuators do commonly fail. Pull the unit off the axle to check it. Easiest way is use a vacuum gun directly on the can, see if the shift fork moves. Lacking a vac gun, run the engine and get a helper to shift the t-case between 4wd and 2wd, look for movement of the fork. HTH
Old 04-13-2007, 11:50 PM
zulusafari's Avatar
Cool. I will take it apart and check it out!
Old 04-14-2007, 08:45 AM
jimk403's Avatar
That is the info I needed to know. Thank you.
NHDiesel
15
08-24-2016 11:05 PM
ez_lle71
01-21-2015 10:43 AM
3J1&3J2Bill
09-06-2013 03:37 PM
OldSmokey
07-17-2007 09:23 PM
Dieselhead
04-25-2003 11:38 PM
Quick Reply: Front axle disconnect
