Front and Rear Drive Shaft U-Joints
Old 06-24-2008, 09:33 PM
grandblanc's Avatar
Does anyone have the part numbers for Spicer u-joints, both the front and rear drive shafts on an 2004.5? What about Brute Force or Precision? Thanks y'all.
Old 06-26-2008, 10:37 PM
grandblanc's Avatar
Talked with a rep from Spicer and they don't have a u-joint that wil fit our trucks without major modifications. Anyone have information on other brand part numbers. I don't want to drop the big bucks at the dealer.
Old 06-27-2008, 11:42 AM
jkitterman's Avatar
Are you out of the 7/70 period?
Old 06-27-2008, 01:16 PM
grandblanc's Avatar
yes, i have 110k on the clock.
Old 06-28-2008, 06:56 AM
JbD
JbD's Avatar
I just put precision #330A in the rear. Good luck with those, I had to use a sledge hammer to break the originals loose.
I put Spicers in the front a year ago, I'll have to look for the part number. I used a Mapp Gas torch to heat them up enough so the injection molding stuff would squirt out, then a vice worked fine.
I had the front d-shaft rebalanced.
2-Stroke
22
06-26-2019 01:12 PM
06RAM2500
10-01-2009 01:26 PM
rodriguez7
12-30-2008 11:57 AM
BLACKBIRD8200
05-28-2008 11:12 AM
Captum
03-02-2008 08:20 AM
Quick Reply: Front and Rear Drive Shaft U-Joints
