Front and Rear Differential Fluid
Anyone have any suggestions for a good fluid to replace the old F & R Diff fluid? I am pushing 20K and need to get that replaced.
Re:Front and Rear Differential Fluid
Been running Redline 75w-90NS since 1700 miles, no problems, about to change it out at 20k, just bought more from a hook at the local supply, and was able to get it for $4 a qt, usually runs $7-$8 a qt though.
Also running Redline in the tranny (Redline MTL) and Tcase (Redline D4-ATF), quiet and smooth, will change it to at 20k.
Look up Redline's website www.redlineoil.com and read about it all, I think it is equal to the quality of Amsoil, which I would have used if I had a source locally, but there was none to be had.
CTDCAL
CTDCAL
I run AMSOIL through out. Its 100% sythetic and works great. You get it on line and at GI Joes and anywhere you find someone that sells it.
Sandemonium
03-27-2009 02:08 PM
4x4not
29
04-09-2008 05:46 PM
gnuesse
09-17-2006 06:48 PM
Iron City
26
09-08-2006 04:59 AM
wilnis
09-17-2004 12:33 PM
