Friction Modifiers for Auto Trans?
Old Sep 8, 2007 | 09:26 AM
rammike's Avatar
I've heard of guys using friction modifier additives in their ATF, anyone know what to use and where to buy? I kinda think my trans may have slipped a little while towing a medium wieght load, pavement was wet, but it seemed like trans, and it wasn't locked up at the time...
Old Sep 8, 2007 | 02:22 PM
ctd89-99's Avatar
Lubeguard in the black plastic bottle. You can get it at NAPA.
Old Sep 8, 2007 | 05:43 PM
HOHN's Avatar
^^ +1
Great stuff.
Old Sep 8, 2007 | 05:51 PM
nickg's Avatar
Adjust the bands/ change filter and fluid.
Old Sep 8, 2007 | 06:25 PM
WestTN's Avatar
Friction modifier REDUCES the holding power of the clutch material. You are already slipping. Friction modifier could finish off your transmission.
Old Sep 9, 2007 | 12:13 PM
MVIEIRA's Avatar
What WestTN said ! Friction modifier will make the oil more slippery. We use it on Caterpillar equip. that use wet multi-disc brakes in the differentials when the brakes get too jerky or shudder. Be very careful how much you add if you use a friction modifier and follow the directions on how much to add to your fluid capacity. This isn't one of those things if a little is good, a lot more is better. You can make the clutches in a limited-slip diff. useless by adding too much. Lube guard is fine if you have a new trans or clutches and you are getting a little shudder on clutch applications, then it would help smooth out the clutch applications. Otherwise I wouldn't use it. Just my $.02 worth.
Regards, Mike.
Old Sep 9, 2007 | 01:11 PM
JSPulliam21's Avatar
Not a good idea!
Old Sep 9, 2007 | 02:19 PM
Mike D's Avatar
Originally Posted by HOHN
^^ +1
Great stuff.
Coming from a handshaker guy... j/k
Old Sep 9, 2007 | 03:16 PM
HOHN's Avatar
I've used lubegard in other auto trannies with good results. Both the red and black bottles.
The yellow bottle works great for handshaker trannies
Old Sep 9, 2007 | 03:39 PM
2Rams's Avatar
I second lube gaurd. Dave Goerend told me it is what he recommends and he even sent me a bottle with my trans. If it is good enough for Dave's transmissions it's got to be good stuff.
Old Sep 10, 2007 | 05:55 PM
kinser5mfan's Avatar
lube gaurd makes a little capsule container called tranny dr. maybe has 3oz. of highly concentrated in it if it helps then you can use the black bottle after a good flushing and filter change ( according to mfg. paperwork)
Old Sep 10, 2007 | 09:05 PM
bama's Avatar
i wouldnt pour anything in mine to intentionally make it slip.......if it shudders,its not holding like it should...........bama
Old Sep 14, 2007 | 10:13 PM
bazdad's Avatar
Friction Modifir For Auto Trans
You have me confused. I just changed the tran fluid today and have not installed the Lube Guard at this time. My tran has 80k on it. Do I wait until problems or pour in the Lube Guard now? Thanks for stearing us correct.
Old Sep 14, 2007 | 10:22 PM
cLAYH's Avatar
Shudder and slipping are two different things. If its a shudder the lube guard will help, if its slipping then nothing short of a rebuild will help.
DTT recommonds filling thier trannies with Dex3 and a bottle of red lube guard.
Old Sep 14, 2007 | 10:44 PM
bama's Avatar
what is it you think its doing when it shudders?
BigBully
Nov 24, 2006 02:50 AM
Mike B
Sep 29, 2006 06:26 PM
I PASS GAS
Jun 12, 2006 08:40 AM
Crimedog
Jun 22, 2005 04:37 PM
Dodgezilla
Dec 20, 2004 04:24 PM
