? on free spin hubs and stock wheels
Old 09-11-2011, 07:24 AM
lowedawg20's Avatar
Has anyone done a free spin hub conversion and kept the stock wheels? If so what do you do about the center cap and the locking hub?
Old 09-11-2011, 08:30 AM
ptm600's Avatar
I haven't done it, but have noticed most cut the center area out of their centers, and they fit over the hubs .
Old 09-11-2011, 08:32 AM
lowedawg20's Avatar
I wander what it looks like? Wish I had some pics. i guess if it was done carefully it would look good.
Old 09-11-2011, 09:13 AM
satellite12's Avatar
Thumbs up Spyntec hubs
I have done the Spyntec conversion on my 05 2500. The kit was awesome its a sweet set up that only takes about and afternoon to do. I highly recomend it, i picked up 2mpg and lost some driveline vibrations.
Old 09-11-2011, 09:21 AM
Spyntec hubs
I tried to post pictures of my hubs but im not good with this computer thing. When you drill the hole through the factory centercap use a 4 1/2in hole saw and use it in reverse that way the hole saw does not rip the crome film off of your centercap.
Old 09-11-2011, 01:58 PM
Highway 4x4's Avatar
I have done it and yes, the Waren hubs do stick out beyond the stock wheel cap about 1.25 inches. There are plenty of picks if you do a search. It kind of bothered me for a while. I was afraid of knocking off fire plugs and such. Actually a tall curb could mess you up with stock wheels and tires. The benefits of the hubs far outweigh the sticking out issue and now I think they look cool as most 4x4's have no hubs. I catch people in other 4x4's looking at them going down the road. If you get aftermarket wheels 10inches wide or larger tires you won't notice them. I used a Dremel tool to make the hole and it worked just fine. All the claims people make about the hubs I found to be true. If you plan on keeping the truck a long time and are on the highway more that in 4x4 it's a go on them. I noticed a reduction in noise and vibes, but I have Michelin MS2's and with a big noisy tire it might not be noticeable.
Old 09-11-2011, 02:07 PM
Brian08Q35004x4's Avatar
Location: This Nazi state of California 2nd home Gilbert AZ under God
See attached
Attached Thumbnails ? on free spin hubs and stock wheels-p9123763.jpg   ? on free spin hubs and stock wheels-p9123764.jpg
Old 09-11-2011, 02:16 PM
Jim O's Avatar
I agree with the above post. I read in diesel power that there is 112lbs of parts that are not turning when the hubs are released, that has to make a difference. I must say that I have not recieved the 2mpg that a previous poster says he recieved but maybe I don't check it that close. I used a hole saw that was just undersized and finishe it of with a sanding drum on a drill press to make the hubcap fit.
Jim O
Old 09-11-2011, 05:18 PM
annabelle's Avatar
X2.............used a hole saw and a rasp.
Old 09-12-2011, 12:39 PM
berettaman's Avatar
I have the Spyntec hubs on mine and I used a 4" hole saw. A 4 1/2" might give a little more space around the hubs but a 4" will work. I did it in a drill press and it came out perfect.
Dave
Hetdiesel
48
04-23-2009 06:08 PM
UnrulyNFS
NCDTR #18
03-30-2009 01:28 AM
jmccart
61
09-22-2008 09:15 PM
TreeFarm
29
02-22-2008 03:32 PM
Quick Reply: ? on free spin hubs and stock wheels
