free power
Old 08-02-2010, 02:22 PM
TXlilbro's Avatar
free power
With all I have done is there anything else I can tinker with that I can get somemore free power out of the old goat?
Old 08-02-2010, 06:45 PM
infidel's Avatar
0 plate, AFC slid full forward, timing to 15-16.
Turn the starwheel all the way or till there is more smoke than you can tolerate.
I would spend the money for a GSK, well worth it.
Old 08-02-2010, 06:51 PM
TXlilbro's Avatar
is a 3k enough or will i be lookin for 4 in the near future afterwords?
Old 08-02-2010, 08:02 PM
Totallyrad's Avatar
Lary swears by the DTR window stickers. He says each one is worth about 30 hp and 100 ft lbs of torque. (I think he's got about 30 on his ride.)
Old 08-02-2010, 08:20 PM
BigGreen's Avatar
What is this a joke or being serious. I don't know enough about our trucks to tell the diffrence.
Old 08-02-2010, 08:23 PM
AggieJustin's Avatar
It's true for the 12V guys, but the 24V trucks require more expensive measure (electronics or injectors).
Old 08-02-2010, 08:26 PM
BigGreen's Avatar
Ok I understand now was wondering why I had not heard of this.
Old 08-02-2010, 09:24 PM
rattlerbob5.9's Avatar
Internals for a p-7100 mechanical injection pump.
Nothing similar in a 24 valve VP-44 electronic pump.
Old 08-03-2010, 12:55 PM
TXlilbro's Avatar
thanks guys, 4k kit is on its way. but where do i go from there?
Old 08-03-2010, 01:37 PM
Midnite's Avatar
I'm not sure exactly where you'll be going, but I bet you'll get there faster!
Old 08-03-2010, 01:48 PM
TXlilbro's Avatar
Lol no question
Old 08-03-2010, 02:09 PM
Paul Marx's Avatar
Okay I'm still a noob , but what is a 3k and a 4k kit ?
Old 08-03-2010, 02:30 PM
JD730's Avatar
3k and 4k kits refers to 3000 rpm or 4000 rpm governor spring kits. Basically a set of springs that replaces the stock set to increase the rpm point where the governor pulls the fuel back. The 3k rpm kit can be run with stock valve springs, but he 4k rpm kit is meant to be run with heavier valve springs. The other free mods make them pretty peppy, but the gov. spring kits really wakes them up.
Old 08-03-2010, 04:00 PM
TXlilbro's Avatar
yes sir, i have 60lb valve springs coming as well. i have a question though, does the GSK make them rev QUICKER as well as LONGER, or is it just for more rpms?
Old 08-04-2010, 11:23 AM
Brendan's Avatar
throttle response will improve, you'll notice a big difference with the 4k kit, a bit touchy in the beginning, but you will get used to it.
w250_93
01-11-2009 10:06 PM
Country23047
20
04-23-2008 09:59 PM
Mark Craig
08-26-2005 07:57 AM
Mark Craig
08-25-2005 04:22 PM
Quick Reply: free power
