Free heater grid delete mod
Old 05-07-2011, 03:29 PM
mikeh1725's Avatar
Since I'm cheap I figured I would gut the heater grid for a free mod and try to gain some air flow. Not expecting alot but here in south Texas I figure what the heck. Fire away with questions if you have any. I think all I needed was a 10,11 and 12 mm wrenches/sockets for the job. I'll be doing another one soon and I'll try for a complete write up.
Mike
EDIT: Will add pics later this evening
Old 05-07-2011, 05:22 PM
Blueboy's Avatar
My grid has been deleted, my relays are still plugged
in, on cold days I get low volt cel. I clear them but
it comes back when it gets cold again. Did you find a
way around this. I see you are Tex you may not get
cold enough to happen.
Old 05-08-2011, 08:13 AM
mikeh1725's Avatar
So far I have deleted 2 of my past trucks and have yet to throw a code on both 03s. I leave the relays in, just unhook the wires running from the relay to the grid. I haven't got a CEL yet and the coldest start I have had was about 14 degrees and it fired like a champ.
Something I have noticed on the 03s, both trucks will still pull the voltage down on a cooler starts as if it's still cycling for the grid heater. Maybe this is why I'm never get a CEL, not sure. Pics will be up this evening, and I should be doing another truck pretty soon, I'll try to get some more pics.
Old 05-08-2011, 09:28 AM
carl48's Avatar
if you do not wait to start you will not get the cel. any time the truck is below 50* start the truck as soon as you turn the key on. you are better off cutting the two grids off rather than trying to remove them
http://i1141.photobucket.com/albums/...rljr48/212.jpg
Old 05-08-2011, 11:34 AM
Blueboy's Avatar
I just relocated batteries to the back, it hasn't
come on since I did this, and its still cold in
the morning. Moving wires did something.
Old 05-08-2011, 11:51 AM
sallyman1's Avatar
what harm does the grid do?
Old 05-08-2011, 12:01 PM
Blueboy's Avatar
I view it as air restriction, nothing to do with harm.
Everyone has their own opinion on that.
Old 05-08-2011, 01:09 PM
mikeh1725's Avatar
For me it is also an air restriction, so why not take it out. Keep in mind I see maybe 10 days of the year in the teens so cold starts are very seldom. This truck I bought had a block heater cord installed so in a worse case situation, I can just plug 'er in.
Old 05-11-2011, 03:41 PM
mikeh1725's Avatar
Finally got pics, disregard dirty finger nails
Old 05-11-2011, 07:25 PM
nvr-enuf's Avatar
Is the increased air flow for power for fuel economy?
Old 05-11-2011, 07:34 PM
AH64ID's Avatar
3rd gen's use an intake air temp of 66*F for the grid heaters.
Old 05-12-2011, 05:35 PM
mikeh1725's Avatar
In theory both...
However, it's probably some improvement in air flow, however I doubt you can tell. Then again, it can't hurt, right?
Red3quarter
11-08-2008 04:11 PM
DWitcher
11-07-2007 08:26 AM
CL2000
31
07-17-2007 02:25 PM
98.5POS
29
12-23-2006 11:39 AM
Quick Reply: Free heater grid delete mod
