FP guage write-up?
Old 01-19-2008, 08:54 PM
Teddyh28's Avatar
FP guage write-up?
Anyone have a write-up on details in installing a FP guage on a 98.5 24v?
Old 01-20-2008, 01:32 AM
Tate's Avatar
On the early 24v's, there is two brass plugs in the top of the fuel filter. Take the front most plug out, and hook your FP gauge into that. 1/8" NPT. If you're using a mechanical gauge, get a needle valve to reduce the pulsations, as well as a shut off in case of a leak.
Old 01-20-2008, 04:40 AM
1-5-3-6-2-4's Avatar
yup.......-2 NPT (1/8th") to 1/4" JIC = good to go. the ones closest to the center are post filter the ones to the outter edge are prefilter. you want post filter reading. or even better tap the fitting at the VP$$ inlet for the most accurate readings.
Old 01-20-2008, 06:42 AM
Teddyh28's Avatar
gotcha thanks
Old 01-20-2008, 08:16 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Mine is set up to monitor post-filter readings.
Old 01-20-2008, 10:53 AM
psd tuner's Avatar
how about a newer truck like my 02, i have mine jerry rigged in there. i tried to find something to screw on to the test port but cant find any thing, i would like something more permanent.
Old 01-20-2008, 12:37 PM
I'm not sure where the '01-'02 trucks have test ports.........BTW I do not run my guage to either of these fittings. these are just auxilliary test ports. my 1/2" lines and fittings take up the whole top of the filter housing, I have to moniter in the VP inlet. I should get a picture, I NPT tapped the fitting at my VP, and put a remote needle valve in the guage line. its like an octopus with all the big fuel lines.
Old 01-20-2008, 02:20 PM
hink's Avatar
http://www.vulcanperformance.com/ser...nection/Detail With this adapter, I believe you remove the Schrader fitting and put this in it's place to hook up ur FP connection.
Old 01-20-2008, 03:46 PM
heres my current setup...........the 1/2" JIC swivel on the inlet of myVP is more than big enough to tap for the 1/8" NPT to the guage. you can use the schrader port. but I like mine because I see exactly what pressure is entering my VP44 at the immediate entrance to the pump no guess work, no pressure drop, no restrictions.
Old 01-20-2008, 11:34 PM
psd tuner's Avatar
thanks to all of yall. i got some ideals what i need to do.
DrMoab
09-12-2007 03:30 AM
capt.Ron
19
10-26-2005 02:16 PM
Rob_OBX
18
07-20-2005 12:02 AM
MikeyB
01-14-2004 05:35 PM
tobyw
52
10-12-2003 08:55 PM
Quick Reply: FP guage write-up?
