Fox Steering Stablizer
Old 06-18-2007, 04:07 AM
pet05's Avatar
Fox Steering Stabilizer
http://www.thurenfabrication.com/ramstab.html
Anyone running this setup? Is the factory shock stabilizer junk?
Let's here some reviews....
Old 06-18-2007, 07:00 AM
goodeyesniper75's Avatar
the stock one is pretty crappy but it works usally...the thuren one is really nice and probably 10x better then the stock one....all his stuff is.
Old 06-18-2007, 08:01 AM
BlackSunShyne's Avatar
I just put mine on last week. I took pics of the stock vs. Thuren side by side on the floor, and on the truck. I will post the pics here this evening when I get home.
I have had it on about a week, so far, so good!
Old 06-18-2007, 08:19 AM
E-Train's Avatar
I've got it
I've been running mine for 3 or 4 weeks and I think it's great. Do a search on my Thuren install and there are pictures of the truck and the stab.
Old 06-18-2007, 11:07 AM
pet05's Avatar
Does the Thuren Stock Stabilizer shock MOVE AROUND? It is only clamped on, unlike the factory which uses a bolt hole. So, does the Thuren need adjustment due to movement?
What does it help with? Death wobble?
Old 06-18-2007, 11:39 AM
ptgarcia's Avatar
No adjustment necessary, and no, it won't move around. That clamp will supply way more force than needed to hold it in place. Most aftermarket stabilizers clamp on with (2) u-bolts and they don't move. The bearing surface of that clamp must be 10x larger than a dual u-bolt setup.
Old 06-18-2007, 02:04 PM
I was a little concerned with movement when I ordered as well, but ptgarcia is right, this clamp is NICE. Huge surface area, espcially when compairing it to a dual u-bolt setup. I have had no slippage with mine.
Old 06-18-2007, 03:34 PM
pet05's Avatar
How are the results? Did it help with DW and make the steering tighten-up?
Old 06-18-2007, 03:36 PM
E-Train's Avatar
Not to worry
This thing ain't moving. The clamp is big and the reason Don doesn't use the factory hole is because the Fox shock is longer then the stock. The price is good and it works so I say go for it.
Old 06-27-2007, 05:16 PM
pet05's Avatar
I also ordered the Fox Stabilizer but Don does NOT include instructions. I am having a hard time removing the factory stud where the factory shock mounts to the bar. I removed the bolt but then when I removed the nut from the other side, the factory shock stud does NOT want to come out.
Old 06-27-2007, 05:33 PM
jtnm's Avatar
I had that problem before.
The taper shaft gets rusted up. Soak it down with some penetrating oil & let it set for 10 to 15 minutes. I used a small pipe wrench to turn it a little bit to break it loose.
Old 06-30-2007, 11:33 AM
Luvnacumns's Avatar
I just installed mine.... DOn ROcks!!!! No more death wobble and truck drives soooo much smoother!!
Old 06-30-2007, 11:39 AM
Rollin' Smoke's Avatar
why would the truck drive alot smoother? just curious
Old 06-30-2007, 11:58 AM
firemansdiesel's Avatar
You will have more control going over rougher terrian w/ the steering. No white knuckles on the wheel.
Old 06-30-2007, 12:09 PM
ok, so the steering just has a better feel then. thats what I thought.......thanks
Quick Reply: Fox Steering Stablizer
