PDA
View Full Version : found a good place 4 switches on an 06
texaspower19
04-12-2006, 08:18 PM
found a plce to mount my switch 4 my quad box. tell me what yall think.
http://www.dieseltruckresource.com/pics/data/500/39896quad_switch.JPG
Cowboy45
04-12-2006, 10:22 PM
I like that, I was going to use that spot for my air bag gauge if I ever get them. What is the hole just to the right of that, is that just for the light?
texaspower19
04-12-2006, 10:29 PM
its so you cann pull that pannel off it has to slide down before you can pull it out, u have to take all of the stuff in front off(by taking the screws out) it to get to the screws on the pannel the switch is on.
texaspower19
04-12-2006, 10:46 PM
Looks good, I was gonna put some things there too but I diddn't want to pry on it too much.
How'd you get it off ? Are those little white marks where you pryed on it?
.........Jim
it wont pry off its got too screws in the bottom, u have to take every thing apart from the floor up. its not too bad 7 screws in all, you start buy taking the little ruber cup holder thing out, 2 screws their, take 4wd boot and pull up theirs a screw under their. then u have to take that piece off plastic off(turn the 4x4 boot straight up and down to get the plastic piece over it), then theirs 2 screws on the next piece youll see one on each side, take those out. then pull the up boot up off the plastic piece, and slide the plastic piece back. then their are 2 screws on the bottom of the piece were my switch is. Take those out then put your hand in that little hole in the center and pull down. and you should have it. :) :)
