Fog light switch
Old 01-08-2009, 11:06 AM
xzaq103's Avatar
Fog light switch
Can a 99 and up(the kind you pull) fog light switch work in a 98? Also how hard would it be to wire foglights up to it?
Old 01-09-2009, 02:52 AM
dozer12216's Avatar
Without looking at mounts, I see no reason you could not. Have to add a wire into harness also. Personally I would wire separate switch and not fool with it. There are some aftermarket lights that fit well. Just look.
Old 01-09-2009, 08:09 AM
cody_d's Avatar
let us know what you find out. i have been looking around at putting fog lights in my truck, but dont really want to put in another cheap ugly switch
Old 01-09-2009, 08:20 AM
Kansascrewcab76's Avatar
I don't know if it will help, but here is how a 98 looks:
I know that the wiring is there from the factory, just find the switch and panel from a bone yard add lights to the bumper and go!
Yes I do this for a fact because that's what i did.
Old 01-12-2009, 02:03 PM
xzaq103's Avatar
The ones for 99+ look like the type in a 3rd gen.
Old 01-12-2009, 04:20 PM
92red's Avatar
xzaq, I think you're talking about the switch that is the end of the blinker stalk and you pull out (toward the door) on it. Is that the one?
If it is, I would highly recommend that you consider another option. Replacing the blinker stalk is a ~$125 proposition. If that's not enough to turn you off, I'd also offer to you that the failure rate of that switch on the end is pretty high overall. So you'd be looking at spending a lot of $$ for a known weak part. When the one in my daily driver (PT Cruiser) failed, I just pulled the fuse and let it go.
Good luck to you either way you go.
Old 01-12-2009, 04:33 PM
DHT
DHT's Avatar
Power Mirror Question????
Can the Non tow power option be added to the tow style mirrors or can a 3rd Gen Power tow mirror be used? I bad need the tow and power thing together!! Thanks!
Old 01-13-2009, 10:03 AM
VADSLRAM's Avatar
My 99 has it incorprated into the on dash light switch. twist **** for lights, pull **** for fogs and an indicator lights up to show fogs are on. If that is what you mean I think it would fit but I don't know what harness plug you have and if it will work. If your junk diving just make sure you clip the plug off also and you should be fine. I didn't see a relay on mine but I was planning on wringing out the wires anyway. I bought some new relays and I'm going to heavy gauge wire from bat to relay to lights, hopefully I'll get a few more candles that way.
Flying Ram
01-31-2009 09:10 AM
ollie32
08-29-2008 08:44 AM
carharttfarmer
06-15-2007 10:00 AM
redramnc
03-28-2005 06:58 AM
MaroonCumminsInOre
09-21-2004 07:35 AM
Quick Reply: Fog light switch
