Fog light and A/C Protection
Old 01-02-2005, 12:21 PM
truckjunkie's Avatar
Hi guys - two questions:
1) Has anyone found any of the wire mesh type protectors for these fog lights yet? Just curious, I thought they'd look good on the front of the truck. If not, I guess I'll get some of the stonguard stuff. Is there anywhere else I can order the 3m stuff from other than stonguard?
2) Can someone point me to a site that sells protectors for the opening in the bumper? I only have about 8K miles on my truck so far, and already have a couple of 'dent's in the bottom of the ac condensor from crap coming in through that non--protected opening.
Thanks....
Old 01-02-2005, 02:54 PM
MikeyB's Avatar
I have the Stoneguard 3M material covering the foglights. I highly recommend them.
For the slot in the bumper I used a sheet of heavy gauge square hole screen. Mounted to the backside of the bumper. I did this because a bird went through the slot and made a nice dent in the condensor. I have a pic in the photo gallery.
MikeyB
Old 01-02-2005, 05:09 PM
Jeff in TD's Avatar
After loosing a fog light, I put on stoneguard, and haven't had a problem since.
I also had some dings in the Condesor, and I elected to go with the Kibly guard.
http://www.kilbyenterprises.com./
It is a metal grate that installs between the stock brackets and the condensor. It even comes with some wire to hold things up while you install, and the top and bottom wrap around the condensor to keep those fins from getting bent when you lean over the engine.
There is a photo of mine in my gallery.
Old 01-03-2005, 06:35 PM
Where did you guys that have used the 3M Stoneguard stuff purchased it?
Old 01-03-2005, 11:43 PM
Jeff in TD's Avatar
http://www.stongard.com/sgcontent/default.asp
Old 01-04-2005, 08:21 PM
BNH4221's Avatar
concur on the Kilby Guard. Well made and a good peace of mind.
Steve
fade94
09-15-2009 12:53 AM
fjbiker86
37
12-09-2007 07:29 AM
JD 70
13
12-30-2005 11:58 AM
KansasMan
08-25-2004 08:30 AM
TurboTed
24
05-27-2004 09:23 AM
Quick Reply: Fog light and A/C Protection
