Flux 3's and a Helix 2 in a towing truck?
Old 01-07-2007, 10:25 PM
judge88's Avatar
lots of water (no menthenol) and lots of air. 3's are big but the cam will help out alot. still might get toasty. i tow with my truck sometimes but leave the boxes off and my egts dont get past 1250.
Old 01-08-2007, 05:35 AM
lmills's Avatar
I have zero problems towing with mine. Egt's stay in check and there is plenty of power. You just have to have the air to back it up.
Old 01-08-2007, 07:29 AM
DTR Advertiser
Timinva's Avatar
You should not have a problem. Turn your electronic power down and keep your rpms up to provide good airflow with your single charger. Tim
Old 01-10-2007, 12:46 AM
D.Wiggs's Avatar
I tow with mine and I don't even have the Helix 2 yet, I still have the ATS cams. I run the Smarty on #9 and the TST on 1/0, 0 timing, 1 rail pressure, and the TT05 program (going to change to the 03). I have only towed about 8,500 lbs. with about 1,000 pounds of cargo in my truck plus whatever my truck weighs (I would guess around 9K). Hope this helps.
bradler
02-18-2009 12:43 PM
OldSmokey
19
03-26-2008 05:11 PM
metal_miner
52
06-23-2007 02:52 PM
O.T
05-30-2007 08:55 PM
MoparRiggan
01-10-2007 03:31 PM
Quick Reply: Flux 3's and a Helix 2 in a towing truck?
