PDA
View Full Version : Fluid Damper???
Jpw
05-19-2007, 11:45 AM
What are fluid dampers and what do they do? is it worth getting? they are saying up70+ HP and 30 lbs torque... please help me out lol still a noobie,
Thank you much for your input
Jpw,[dummy] [dummy]
t-boe
05-19-2007, 11:50 AM
I don't know if they make one for the 6.7 yet. It basically takes out the harmonic vibrations out of the rotating assembly. I don't think it'll give that much extra power, but it'll help keep your motor happy for a long time.
morkable
05-19-2007, 12:46 PM
They claim 45 hp. I am not sure if it does, didnt have a baseline to tryout, but IMHO it is definately worth the money
kevin
Jpw
05-19-2007, 08:44 PM
Cool thank you for the info guys
PourinDiesel
05-19-2007, 10:51 PM
They dont claim 70hp, or 45hp. Fluidampr claims 4-5 hp on an other wise stock truck.
I have one on my truck and its great. A must for the modifcation list.
The 6.7L has a silicon filled stock damper so a Fluidampr is not needed in my opinion.
moparmatt
05-19-2007, 11:19 PM
is it fairly difficult to change? i would think so seeing as how it is pretty tight just to get a new belt on
morkable
05-19-2007, 11:39 PM
Its easy to change,, but the belt can be a bit tough. On the box that mine come in it said up to 45hp gain,,,, but I cant say that it is true, or not true
Kevin
53 willys
05-19-2007, 11:52 PM
how much is a stock 6.7L dampener???
and how much is a Fluid dampener aftermarket??
maybe a stock 6.7L dampener would be a cheaper alternative with the same results????
what do you guys think????
PourinDiesel
05-20-2007, 07:27 AM
Doubt it. Just get the fluid damper. The new 6.7L damper is big and will probably run big money.
wiskeyVI
05-20-2007, 11:12 AM
Along the lines of dampners, is there an underdrive pully system for the power steering, that anyone has seen???
My truck seems to resest having the wheels turned while at idle. It's fine if I start to move, but sitting as in a parking lot, it seems to bog down some.
Jpw
05-20-2007, 10:06 PM
Thank you Thank you once again for the info, keep it coming guys
Sevir
05-20-2007, 10:23 PM
any notice increase in MPG as they advertise?
Ghost Ram
05-20-2007, 10:31 PM
what is wrong w/ the stock damper?
53 willys
05-20-2007, 10:37 PM
it's rubber...the fluid style absorbs more vibrations then rubber.:cool:
jwb600
05-20-2007, 10:58 PM
every single person I know that has one say they work great. I would like to out one on my rig at some point
Ghost Ram
05-20-2007, 11:06 PM
im familliar w/ how they work. i have used them on my race cars in the past. but, they are not benificial to a stock motor unless the factory unit isnt doing its job. i have seen plenty of stock cummins motors go several hundred thousansds of miles w/ the stock damper so i doubt they dont work well.
that being said, if you are making ALOT more power over stock or if you have changed the physics of the motor (bore, stroke, rod ratio, etc.) than the stock damper may not work as well because thats not what it was designed for so an aftermarket damper would be the way to go, but i would stay away from fluidampr and go w/ an ATI.
Gannetpeak1
09-13-2007, 09:17 PM
How do they know it works great? Just curious what engine or drive train parameters are monitored to determine effectiveness? I wouldn't know what to look for, maybe it just seems to run a bit smoother? Thanks.
PourinDiesel
09-13-2007, 09:45 PM
With my setup minus Fluidampr it used to sound like the tranny was going to vibrate out of its home when I didnt match rpm's in 5th gear.
I installed the Fluidampr about 2 years back and it cut the tranny vibes down by about 75%....
Night and day difference in vibration reduction in my transmission.....it has to be making life better in my engine.
Dieseljunkie
09-13-2007, 10:10 PM
I will eventually be putting one on my truck, but not for a while. Got a long list of mods to do first :)
Scott
