Fluid Capacity in rear diff
Old 09-22-2009, 07:21 PM
RobV2500's Avatar
anybody know the fluid capacity in the rear differential? any suggestions on fluid manufacturers i should use?
Old 09-22-2009, 07:43 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
11.5 Rear Axle MOPARŽ Synthetic Gear Lubricant SAE 75W-90 Quart part#05010320AA Fill capacity 8.8 Pints 4.2 Liters
Old 09-22-2009, 08:05 PM
RiverRat2's Avatar
yep and if you do some Heavi-duty towing,,,,, get the anti-wear additive, slickem stuff to go with it,,,,
If you are out of warranty,,,,,,,, Any of the quality Synthetics will, work,,,,, Aka,,, Royal Purple, Amsoil, etc
Old 09-23-2009, 12:44 AM
TexasCTD's Avatar
Any GL-5 rated synthetic gear oil in 75w90 will work great. I use Mobil 1 with great results.
You do not need any additives in our AAM axles. Just the gear oil.
Old 09-23-2009, 12:56 AM
Dr.Dizzle's Avatar
Thumbs up
I agree.
Old 09-23-2009, 08:48 AM
LongRanger's Avatar
Some people use additives to reduce/eliminate any chatter you may have while turning. Pay attention to the recommended fill level, 1/2" below the plug, or you will get leakage at the seal.
Old 09-23-2009, 10:00 AM
92'1stGen's Avatar
+1
OP: I used Royal Purple 75w-90 because it was readily available, and I've been happy with it. It took just under 4 qts for the rear diff and just under 3 for the front.
Old 09-24-2009, 11:45 PM
Cummins Guru
BigIron70's Avatar
If you are still under warranty I would use what Chrysler recomends, and don't forget to save your receipts. First thing any dealer will ask you when you bring your truck in with a diff noise. When was the last time you changed your fluid in your diff.
banana
12-01-2009 11:44 PM
LockedandLoaded
01-17-2008 02:51 PM
wreedCTD
09-07-2007 07:01 AM
Big Smoky
09-18-2006 05:19 PM
Relentless
10-06-2003 06:46 AM
Quick Reply: Fluid Capacity in rear diff
