fluid capacity on np271 transfer case
Old 08-15-2008, 10:44 AM
rmalone's Avatar
Just like the title, is the service manual correct at 4pints atf +4?? I know it's pathetic to not take the service manual at it's word, but you know how it is.
Old 08-15-2008, 02:06 PM
TexasCTD's Avatar
When it starts to drain out the top hole, you know you have enough.
Sorry, I couldn't resist. I honestly don't know the "exact" amount. I just always have plenty of ATF on hand to do the job and more. Whatever I don't use goes in the next time.
Old 08-15-2008, 05:51 PM
GOT BOOST?'s Avatar
2 quarts of ATF, straight from the manual. Jay
Old 08-21-2008, 11:48 AM
311Hemi's Avatar
So many people say to just fill the TC until fluid starts coming out, but if you use 2 qts like the service manual states it does not start coming out and is below the plug line.
I would have to assume I am fine with the 2 qts I put in.....and should not go buy a 3rd qt just so I can fill it all the way to the plug hole?
Old 08-21-2008, 01:01 PM
RD TRCTR's Avatar
When I changed mine it ended up taking almost 2.5 quarts (5 pints). I'd recommend having an extra on hand just in case.
Old 08-21-2008, 03:32 PM
311Hemi's Avatar
The question is....is it supposed to take 2.5qts, or is the 4 pints (2 qts) what should be filled?
Old 08-21-2008, 07:35 PM
coblanchard's Avatar
It should be filled until it comes out of the filler hole with the pickup on level ground.
D06DODGE
0
11-13-2011 10:27 PM
fj40chance
03-13-2010 04:11 AM
skahla
11-12-2009 09:43 AM
snowrodeo
09-18-2004 10:16 AM
Quick Reply: fluid capacity on np271 transfer case
