PDA
View Full Version : Flat Bed Is Done..
Colo_River_Ram
08-02-2008, 10:02 PM
Weighing in at 11,000 lbs..
http://www.dieseltruckresource.com/pics/data/500/medium/P7260032-LR.jpg
http://www.dieseltruckresource.com/pics/data/500/medium/P7270080-LR.jpg
http://www.dieseltruckresource.com/pics/data/500/medium/P7260056-LR.jpg
http://www.dieseltruckresource.com/pics/data/500/medium/P7260055-LR.jpg
Machinos
08-02-2008, 10:19 PM
Just the truck and the flatbed weigh 11k?
Colo_River_Ram
08-02-2008, 10:52 PM
Yes C&C truck about 8.600lb + 2,400lb bed = 11,000lb
catnfool
08-03-2008, 01:09 AM
you forgot your mesh in the back window- unless you wanted a slider anyways!!!! Nice work by the way; I moonlighted for a fab shop in town and appreciate your fenders;)
Colo_River_Ram
08-03-2008, 12:20 PM
Thanks Cat.
Actually the mesh as you call will be a CNC plasma cut design, It will be a bolt on in case if the rear window is broken and needs replaced (don't want to pull a bed to replace the glass) .. same goes with the LP as well, the trap door that gives you access to the truck/trailer electrical is located on top of the LP [coffee]
chaikwa
08-03-2008, 04:43 PM
Actually the mesh as you call will be a CNC plasma cut design, It will be a bolt on in case if the rear window is broken and needs replaced (don't want to pull a bed to replace the glass) .. same goes with the LP as well, the trap door that gives you access to the truck/trailer electrical is located on top of the LP [coffee]That is one nice, NICE body! I build truck bodies and trailers for a living and I KNOW how much work went into that. You certainly pay attention to detail!
chaikwa.
Colo_River_Ram
08-04-2008, 01:37 AM
Here is a couple of pics of one of the trailers(built it too) I pull with the truck
http://www.dieseltruckresource.com/pics/data/500/medium/P7260027-C-AT.jpg[
http://www.dieseltruckresource.com/pics/data/500/medium/P7260042-C-AT.jpg
catnfool
08-04-2008, 01:42 AM
OK, then it passes with FLYING colors then[laugh] The last one we built was all aluminum for a dually- turns out this new calcium cloride(ice melt) they put on our roads doesn't like AL much[yuk] We had to rip it off and paint it; whats the fun of having AL if it doesn't look like it[duhhh]
I really like your boxes- and a person REALLY shouldn't HAVE to plan the "next" LP failure[duhhh] DODGE, are you listening[guitar]
Tedonlin150
08-04-2008, 02:47 AM
So what do you haul on that huge trailer? Oh and very nice truck by the way
RobG
08-05-2008, 09:27 PM
NICE flatbed!!!
Question... what's the spacing from the top of your tires to the underside of the deck? I'm still trying to figure that out for the deck I want to build...
Rob
Colo_River_Ram
08-05-2008, 10:02 PM
Rob,
here is the link to the C&C upfitters guide, if your a standard cab w/bed you could probably still use some of the data... the bottom of my bed is 9" above the frame..that is max tire travel listed in a crab situation according to the dimensions / Views and chart section..
http://www.dodge.com/bodybuilder/2008/dm/dmmo.pdf
6cylinders
08-06-2008, 04:33 AM
Very nice work! Like the color choice, it shows off the workmanship much better than black would.
Colo_River_Ram
08-06-2008, 10:44 AM
Thanks 6-C
Ted it is used to haul tubing to and from the oil/gas locations I work on..
http://www.dieseltruckresource.com/pics/data/500/medium/P8040013-tubing.jpg
rfeiller
08-10-2008, 11:25 AM
how did you attached the bed to the frame, with the restrictions by dodge of drilling or welding top and bottom flanges? very attractive bed.
Colo_River_Ram
08-10-2008, 03:45 PM
I used all existing holes, the upfitters guide gives you the specifics on what you can or can not do.. When I get some extra time I'll post a slide show of the project.
djdc
08-11-2008, 07:19 AM
Very nice setup.
Looking at your pictures reminds me how much I enjoyed hunting in NW Colorado. I just love that area. We hunted for 10 years there between Douglas Pass, Rangely and the Utah Boarder.
rfeiller
08-11-2008, 01:42 PM
i would appreciate seeing those photos is you get the time
rburm
09-15-2009, 10:03 PM
for some reason i cannot see the pictures, could you please repost?
mudwisr2
11-22-2009, 08:24 AM
pics aren't working
sdseva
11-22-2009, 11:11 AM
^^x2
Black Dog
11-22-2009, 02:13 PM
x3. Now I gotta see them, after all I read about them. Please repost the pics.
Colo_River_Ram
12-09-2009, 08:31 PM
Pic Re-post..
The pics disappear when you re-organize your photobucket acct.
Click on the small pic for a slide show of the project:
http://s427.photobucket.com/albums/pp353/SLOWECO/th_P5060044.jpg (http://s427.photobucket.com/albums/pp353/SLOWECO/?action=view&current=a2426e6e.pbw)
Stills:
All LED Lighting:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/Bullet-QB.jpg
Both trailers and the truck bed has the same bed width / system to allow interchanging of accs:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/P7260056-AT.jpg
1 1/2" T&G solid rubber "Rumber" decking - B&W 1500 turnover ball flat bed system:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/P7260034-AT.jpg
42' GN - Elec/Hydraulic Actuator - Develops 1600 psi in under 2 sec:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/P3010015.jpg
SS hard and woven lines for the disc brake system - 12K HD axels x2 - 6K overslung spring pack x4:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/P3010016.jpg
Strap tie down system - 2" receiver tubing for stake pockets allow for future additions:
http://i427.photobucket.com/albums/pp353/SLOWECO/D_T_R_Pics/PA240004.jpg
blackbanshee
12-10-2009, 07:44 PM
That is just sick. Well done, sir.
BlackBanshee
rburm
12-11-2009, 02:43 PM
thank you for posting.
looks very practical, functional. well done!!!
Colo_River_Ram
12-11-2009, 06:52 PM
Thanks for the compliment guys..
It's amazing what you can do if you have plenty of wire and gas for the ol wire feed..
mudwisr2
12-12-2009, 10:09 PM
Very nice.
03RAMBUNCTIOUS
07-30-2010, 02:12 PM
HOLY MOLY, that's amazing!
country pride
08-08-2010, 08:12 PM
Hey man that is some more bed can u send me some more information on the paint you used i need to paint mine and i would like to see some more pics of your trailer
boostjunkie1
08-08-2010, 09:34 PM
Awesome JOB!!!!
Mark Hodowanec
02-25-2012, 07:56 AM
very nice!
