How to fix code p0380
Old Apr 21, 2005 | 04:11 PM
popeyesides's Avatar
Howdy,I know that code P0380 is glow plug circuit relay,but how or what do I do to fix it.Any info would be great.Thanks.....
Old Apr 22, 2005 | 08:06 PM
RCW's Avatar
RCW
The most common reason for that code is that the intake air preheater relay has failed. Check your relay, and if it is bad you can replace the grid heater side with a very inexpensive universal relay from an autoparts store.
If the relay is good, then check your grid heater elements with a continuity tester and make sure that #1 is not burned out.
Rickcher
Jul 13, 2009 01:22 PM
popeyesides
Apr 6, 2007 10:42 AM
Bad Ramer Jamer
Oct 20, 2005 07:18 AM
popeyesides
Apr 8, 2005 08:12 AM
popeyesides
Apr 7, 2005 11:06 PM
