PDA
View Full Version : First Gear in Automatic
kevinn
11-09-2002, 08:58 AM
A while back my grandfather was trying to pull out his 24 ft travel trailer from the side of his house. The truck and trailer were at an angle. Anyway, when he would give it gas in first gear (automatic), he couldn't get the trailer to move. He couldn't even get his wheels to spin. Is there a problem with his transmission? I had the same issue with my truck in a different situation. Is this just due to the TC not locking up in first?
chuck3
11-09-2002, 09:06 AM
No thats not uncommon for a stock truck. You may need a little help from the Edge Boys. [laugh]
kevinn
11-10-2002, 04:30 PM
So its only an engine creating power issue? I would have thought that the torque on a stock CTD would be enough to spin the wheels. Guess I need to get the Edge....
Superduty12v
11-10-2002, 05:20 PM
Not neccessarily a power issue as much as a slushbox issue. It prolly wouldn't have done that with a manual. Manuals transmit more power and there's no fluid couplings to slip underload.
kevinn
11-10-2002, 07:51 PM
I'm sure that wouldn't happen with a manual. I'm wondering if a transmission upgrade with ATS or DTT would resolve that. On several truck descriptions, specifically people who have had their a/t upgrades with DTT, they mention 89%, 90%, or 91%. Is this the percentage of lockup power?
kevinn
11-10-2002, 08:43 PM
Would this upgrade solve this issue?<br>
AlpineRAM
11-11-2002, 07:59 AM
Straight6: The number on the TC is a measure of fluid coupling. The higher the % the lower the stall speed. So for pulling a heavy trailer a lower number is preferrable. (More torque multiplication). <br>I'd check the tranny for slippage before blaming it on not enough power. My truck would spin its wheels on dry roads when taking off when still stock. <br>Ask about tire wear now. <br><br>Anyway, before doing any mods to the engine do two things: <br>First get some gauges- EGT, Boost, FP and Tranny temp<br>Second- check your tranny. The stock tranny will handle some light bomb like the EZ- if its in good condition. If it's sub par the bomb will just show this up. And if there is something wrong with it, get it corrected. A clutch that slips can cause a total tranny failure when not corrected in time.<br><br>HTH<br><br>AlpineRAM
