Finally time to start upgradin the 03
Old 01-10-2008, 04:24 PM
tonyme13's Avatar
I have started buying parts for my 03 since I'll be home from Iraq soon and just wanted to see what everyone thinks of my potential setup.
Already bought
*****'s Whistler Intake parts w/outerwears cover
MBRP 4" 409 stainless turbo back exhaust
285/70/17 Kumho Road Avenger KL78 (anyone else used these?)
Need to buy
Edge Juice w/Attitude(was gonna go Smarty but I want the adjustability and built in safety, would you guys also buy regular gauges just in case?)
Airdog 150(gotta see if lift pump was ever replaced and put in tank)
?Quadzilla Rail Pressure Guage?(haven't decided on this help me out)
Can anyone think of anything I'm leaving out that I may need, I'm only looking for mild right now not wild. I want to hopefully stay away from getting a new turbo or clutch for awhile, but I will keep a rainy day fund stashed away just in case. I am pretty good about my skinny pedal so I'm hoping I'll be alright for awhile, until the horsepower bug really kicks in.
BTW First Post
Old 01-10-2008, 05:15 PM
Cold Diesel's Avatar
Having tried edge,BD, and finally Smarty I would definately go with a Smarty. I use the BD outlook to defuel on egt's but if I was doing it over ... again ... I would probably get the Quadzilla commander instead. Smarty rocks
Old 01-10-2008, 05:21 PM
cquestad's Avatar
Juice with Attitude is a nice set up for the 03. Hot juice is hard to beat on a stock truck. Smarty will slip the clutch...
What are your hp goals....answer that first.
Old 01-10-2008, 05:29 PM
tonyme13's Avatar
I'm looking for the 400-450rwhp range tops, what do you think I would be running for rwhp with the setup I listed above?
Old 01-10-2008, 05:43 PM
OldSmokey's Avatar
Go with the Attitude if thats where you want to end up. Run the regular program until you want some more power. Then upgrade to the hot juice, get a OFE and a 62/12 turbo and it will be really fun to drive, and safe. Every Attitude only powered truck ive seen dyno were right at 400 hp and 750ish Tq.
Old 01-10-2008, 05:49 PM
tonyme13's Avatar
How much does a 62/12 run for pricewise? and btw thanks for all the help
Old 01-10-2008, 06:35 PM
No hot juice for 03 ...or there was not when I had one anyway
Old 01-10-2008, 07:21 PM
BRayls's Avatar
spend the extra dollars on a 304 ss exhaust if you see harsh winters.
Old 01-10-2008, 07:27 PM
SlowSixSpeed's Avatar
If you want a 450rwhp daily driven 03 you pretty much have to get a smarty + pressure box + larger turbo + stronger clutch.
You might be able to get the same hp with other electronics but the smarty will drive the best and smoke less.
If you had a 04.5+ all you'd need is a smarty to hit 450.
Heck I have a Smarty#7 + MP8 at 100% + silberbullet turbo on my 03HO and have dynoed best at 438hp and a low of 390.
Sure my truck is fun to drive but it still need's even more to hit 450.
Old 01-10-2008, 07:38 PM
Fire Rescue124's Avatar
Well i hit 377 with my sig set up on 7 wild TM so if i got a Quad box alone i bet i would hit or even top 450 oh and a clutch........ but i could be wrong. i could always run a beta program and get even better.
But with me not having used any other programmer or chip i can't tell you it its better or not but i love my Smarty and it drives very nice and still on stock clutch not sliping yet!!!!
Old 01-10-2008, 08:27 PM
DTR 1st Sergeant
soulezoo's Avatar
You mean like twins???
Old 01-10-2008, 09:03 PM
OldSmokey's Avatar
The hot juice for 03s is only 150 hp, not 180, and it adds pressure on the 305 motors. And a 62 will run you from $1200-$2000 depending on which one you pick.
Old 01-10-2008, 09:08 PM
OldSmokey's Avatar
I see your from SD to tony, there arent many of us on here!!
Old 01-10-2008, 10:33 PM
RDyson's Avatar
You probably don't need the rail pressure gauge yet with the mods you have listed. But that looks like a good package to start with. Good luck with the truck.
And a BIG THANK YOU!!! for your service to our country!!!!!!!!!!!!!
Randy
Old 01-11-2008, 03:55 AM
tonyme13's Avatar
BRayls spend the extra dollars on a 304 ss exhaust if you see harsh winters.
I've already got the 409ss in the mail so no luck on changing that, don't really want to spend that much on exhaust right now either. Maybe when this one rust's out I'll switch over, but they use sand where I live and no salt so hopefully that will help.
OldSmokey I see your from SD to tony, there arent many of us on here!!
I'm in the Army and I'm usually the first person alot of people have ever met from SD
I think for the time being I'm going to wait on buying a programmer, I might change my mind and go with a Smarty yet. I really would like the adjustability on the fly though if I'm pulling a horse trailer or camper.
Quick Reply: Finally time to start upgradin the 03
