Finally installed the Max Flow System
Old 05-03-2004, 06:52 AM
procrastinator's Avatar
I went camping last week, it gave me plenty of time to take apart the factory lines and replace them with the Wildcat Max Flow System. This also gave me plenty of incentive to get the job done.
The only problems I had were the same as everyone else. The braided fuel lines are a pain. No fuel showers. I had to tighten a few of the fittings to stop a slow leak.
My fuel pressure runs about 14-14.5 pounds on idle, and when I was returning home pulling my fifth wheel, it never went below 12 pounds on the hills.
Now my truck really is dreaming of new injectors! Come on clutch go out so I can upgrade!
James
Old 05-03-2004, 07:49 AM
RATTLINRAM's Avatar
COOL ,,,,,,,,,,,,,, ain't it?
It makes me wonder how many lift pumps might have lived a little longer with a less restrictive system like this. I gained about 1.5 psi pressure @ idle after installing mine.
Old 05-03-2004, 11:32 AM
MK4288's Avatar
how was the install and about how much it run you to get it all in
Old 05-03-2004, 02:14 PM
HOHN's Avatar
Mine idles at 17-18psi... Can pull it below 11psi, even with 350ish hp. It's a GREAT setup.
IIRC, the kits sells for about $130. Worth every penny.
If you want to go cheaper, call Wildcat and order JUST THE FITTINGS. You can then do up some socketless hose or the like from Summit Racing (etc.) for maybe a bit less money.
Justin
Old 10-07-2004, 07:33 PM
dieselminded's Avatar
Im concidering the max flow system from wild cat does anyone else have an expirence with it?
Old 10-07-2004, 08:55 PM
BOILERMAKER's Avatar
Once you figure out what's going on and finally get it on, it's great!
Old 10-08-2004, 04:07 PM
RowJ's Avatar
Dieselminded
-Cheapest way to solve LP problems of excessive cycling.
-Boosts pressure levels above danger range up to about 450 HP
-Eliminated my need to consider a FASS
-Been 42,000 miles in new LP I installed when I first bgt the truck used...and no drop in Fuel pressure since.
I highly recommend it...especially with newer 1/2" lines!
MK4288 - not what I would call an easy install. One of those where doing it the second time would be about 1/3 the time, IMO
See here - https://www.dieseltruckresource.com/...+MAx+fuel+flow
RJ
streetsmoker
24
05-07-2006 12:26 AM
HOHN
23
12-13-2004 10:33 AM
barracuda
02-21-2004 11:49 AM
gsdog1
15
02-18-2004 12:47 PM
gsdog1
01-14-2004 01:35 PM
Quick Reply: Finally installed the Max Flow System
