Finally decided on which set of twins
Old 06-12-2007, 07:47 PM
CTD06's Avatar
Ok I decided to go with Nathan's twins. Its a HTT 62/71/13 and 80mm S400 any opinions or suggestions on this set?
Old 06-12-2007, 07:49 PM
Luvnacumns's Avatar
Excellent Choice!!!
Old 06-12-2007, 07:59 PM
Luken's Avatar
What's the cost on that setup?
Old 06-12-2007, 08:03 PM
CTD06's Avatar
Its 5600 for the kit, and 200 for high temp ceramic coating on all the hot pipes, manifold, and S400. Plus I decided to have the top turbo ordered with the polished housing (an additional 100 bucks).
Old 06-12-2007, 08:30 PM
abc4yew's Avatar
That is the turbo that I'd use on any future set of twins? Is Nathan spec'ing a bigger wastegate capacity or is it an external waste gate setup... If HTT has enlarged the wastegate capacity ...this is a turbo that will rock with a good s400. You are making alot of people jealous. ks
Old 06-12-2007, 08:40 PM
CTD06's Avatar
He said that an external wastgate is an option... I wasn't sure weather or not to get it.
Old 06-12-2007, 08:51 PM
Luvnacumns's Avatar
Jealous, Yes!! I just ordered the towing twins and will probably update the stock/top one here shortly but I gotta get a tranny!!
Old 06-12-2007, 09:45 PM
Boz007's Avatar
Seriously man, you've been on a roll lately. If you dont mind me asking, what do you do for a living?
Old 06-12-2007, 09:52 PM
PourinDiesel's Avatar
Wow you guys are rich!!$$$$
Old 06-12-2007, 10:36 PM
Luvnacumns's Avatar
WORk !!! No really... I do construction.. Complete home re-make-overs.. Like you see on tv!! Not easy stuff!! I have been pretty fortunate and I am thankful for that!! Life is what you make it!
Old 06-12-2007, 10:54 PM
973604x4's Avatar
Thats what I'm thinking.
I paid $2000 for my entire twins kit!
Old 06-12-2007, 10:55 PM
Luvnacumns's Avatar
My total with powdercoating was $3100...
Old 06-12-2007, 11:09 PM
973604x4's Avatar
re-using your stock turbo shane?
Old 06-12-2007, 11:29 PM
Boz007's Avatar
WORk No really... I do construction.. Complete home re-make-overs.. Like you see on tv!! Not easy stuff!! I have been pretty fortunate and I am thankful for that!! Life is what you make it!
So if someone were to say flip a house, you'd be the guy that comes in and does all the work (if they dont do it themselves)?
Like 97 asked, are you reusing the stocker or using that A5K?
Old 06-12-2007, 11:38 PM
Luvnacumns's Avatar
Yes stock turbo.. I can upgrade to the 62 later but for now Nathan says the combo should get me a little more on the dyno and make like soooo much eaiser towing..
Yep that's what I would do.. Working on a 7-8000 sq ft house right now.. It's four stories!!
Quick Reply: Finally decided on which set of twins
