Filterminder
Old 09-23-2003, 12:06 PM
kimber's Avatar
Re:Filterminder
My filterminder read 35% at 100 miles, so being curious, I reset it. Since then it has not moved-even with a filter that looked like I had used it for a coffee filter. Just go on instinct now.
Old 09-23-2003, 12:13 PM
Steve034x4's Avatar
Location: North of the Frost Line....near Priddis Alberta
Re:Filterminder
I've got 21k kms (about 13k miles) on mine and like Kimber I reset mine a few times during the first few thousand as it read 1/3 used from the get-go. I've not had to reset it for a long time, so I opened up the air cleaner for a look-see and saw that the filter was doing it's job....it was black air side, but clean on the engine side.
I'll be changing mine this weekend, filter minder or not.
Old 09-23-2003, 01:16 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
Re:Filterminder
Filterminder = Worthless
Mine showed that it was 65% used from the day I drove it off the lot. I haven't given it a second look since.
Old 09-23-2003, 02:32 PM
SjLingenfelter's Avatar
Re:Filterminder
Freidn of mine used a dirty dirty air fuilter and drove the truck for 250 miles always on the throttle WOT for a long time. NEVER EVER EVER moved.
Old 09-23-2003, 05:36 PM
mymaur's Avatar
Re:Filterminder
I changed my filter out at 12k and the minder said I had 35% left. However, it was so dirty I don't know how any air got thru at all.
Minder on every Ram I have owned has been questionable. I pay little if any attention to it. Just pull the filter at 12K and change it.
Old 09-24-2003, 05:09 PM
dodgedude361's Avatar
Re:Filterminder
i have the green , yellow, and red one. 9000 miles, and it still hasn`t moved
Old 09-27-2003, 08:00 AM
Mexstan's Avatar
Re:Filterminder
My filter minder went to around 35% from day one. Then I installed a Scotty 3 and it immediately went to 100%. Reset it a few times and it still jumps to 100%. So now I just use it to plug the hole.
Old 09-27-2003, 11:49 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Filterminder
That factory filter minder is laughable at best. I used mine to throw at the dog when he's doing something wrong
BTW, the absolute best filter minder on the market is your pyrometer. When you start seeing your WOT egts coming up past where they normally sit, the first thing you wanna check is the air filter.
Rod
Old 09-28-2003, 11:51 AM
Nevada's Avatar
Re:Filterminder
I have an early build truck, one with the numerical filter that actually moves. From day one, any time I hit 2,500 rpm the filter minder would pull down to 35%, get close to 3,000 rpm and it would drop to 65%. From the day I changed from a paper filter to an aFe drop in it hasn't moved. I suppose it was easier for DC to change the filter minder than recall or TSB its overly restrictive air filter setup.
swampdiesel
18
02-05-2009 09:23 PM
Quick Reply: Filterminder
