Filler Neck Leaking
Filler Neck Leaking
When I was under my truck giving it a coat of POR, I noticed that my filler neck was in bad shape. Recently, while filling up, I started seeing a puddle forming under my truck from dripping. Where can I find a replacement filler neck? I have tried Transfer Flow, but they don't have replacements for 95's. Better yet, is there a way to seal up the one I have? Any help would be greatly appreciated. Diesel's expensive enough without donating it to the concrete under the truck.
You can always make a new one.. take a hacksaw to the oem one and trim off a bunch then replace it with hose. I did this on my truck because I needed the space to mount an aux fuel tank up there. Still fills up and vents just fine.
1 Post
I think they did't use large enough tubing or the bends are too tight because when I go to fill up it always kicks the pump off. I have to fill it at half throttle especially at the truck stops. anybody else notice this?
