Fast idle not working after Juice install
Old 04-08-2007, 01:23 PM
CamperAndy's Avatar
Since I installed the Juice with Attitude (EJD3000BWAM) for my 06 Dodge 3500 5.9 CTD the cold engine fast idle does not work. Anyone else notice this??
Old 04-08-2007, 01:52 PM
m2fsr's Avatar
Mine works fine. What is the outside temp in your area. Mine kicked up yesterday here in Colorado, where it was about 23 degrees Farenheit.
Old 04-08-2007, 03:29 PM
Fisherguy's Avatar
Yours an auto or standard?
Should work with an auto, if it's a standard you'll need to ground pin 22 at the ECM, like explained here
https://www.dieseltruckresource.com/...ight=High+Idle
https://www.dieseltruckresource.com/...=120288&page=2
I did it and it works with my BD
Old 04-08-2007, 04:40 PM
templer's Avatar
Mine is a stick and I didn't have a problem at all?? Since this is a holiday weekend did you try talking to them? They were open on friday.
Old 04-08-2007, 08:25 PM
CamperAndy's Avatar
Mine is an Auto and it worked before. I e-mailed Edge but since it is a holiday weekend I did not expect an answer until Monday but you guys are always here so I had to ask here also.
Old 04-08-2007, 09:32 PM
bluebull's Avatar
camperandy, what's the build date on your truck? You can find it on the engine data plate or the door pillar sticker.
Old 04-08-2007, 11:50 PM
CamperAndy's Avatar
The build date is Jan or Feb 06. I looked it up before but do not remember. The engine was Dec 05 and I purchased it in March 06. So it is early enough that it falls before the June date that Edge says not to use the Juice on, if it is built after June 06. The Juice and Attitude work but a feature of the truck has now stopped working and I was just trying to find out if this was a known issue or something unique to my install.
Sleigher
05-04-2017 02:12 PM
nitrous
09-23-2010 08:34 PM
trik396
03-14-2007 07:57 AM
Neil58
08-14-2006 06:12 PM
Quick Reply: Fast idle not working after Juice install
