Is the FASS system a hard install?
It isn't really that hard to do. The machanic said it should be 2-3 hours, but I think I took about 4. The instructions aren't really that elaborate so I had to read things several times before I understood what it meant. If I had to do it again, I know I could do it in 2-3 hours though. Just sit down and read through all of the directions first. I did this and thought it would be easy, which it wasn't really that hard. Anyone can do it. If you would like some advice let me know.
A 90* drill will speed the install of the mounting bracket. I pretty much had the directions memorized before it even arrived in the mail. Check it out on DPP's site.
Also, as others have done, I didn't use the quick connect at the tank, just straight hose, and two clamps.
The only thing I learned after doing mine was that you should unhook the stock fuel line from the injection pump before you unhook the stock fuel line from the tank. This allows much of the fuel in your lines to drain back into your tank rather than your work area. Just my 2 cents. Eric
modified03
12-23-2008 01:11 AM
johnsjas
04-23-2007 02:46 PM
BCarmicle
13
11-07-2005 04:20 PM
