Fass replacement filter question
Old 05-10-2007, 06:02 PM
6WHEELER's Avatar
I just wonder if anybody with the FASS system is using donaldson filters instead of the fleetguard for the fuel filter. I can get donaldson locally and usually have to order the fleetguards or buy them by the case.
just wondering
thanks
6wheeler
Old 05-11-2007, 08:58 AM
Diesel-Dan's Avatar
If you can find a number to cross to any of our 150 Series FASS units filters.....go for it. Just be sure of the micron rating.
The 95 Series FASS fuel filter cant be crosses over. The filters for thoes units are made just for us by Fleetguard. I hear that the water sep. can be crossed though. BUT I don't have a number for it other than our in-house number.
Old 05-11-2007, 11:00 AM
6WHEELER's Avatar
Thanks Dan, I found a cross to a 5micron and 25micron, just looking for a 10.
I will probley go with the 5 since mind is about ready to change.
Old 05-11-2007, 12:21 PM
Haulin_in_Dixie's Avatar
You are better off with the five micron anyway. Baldwin also makes filters for it that you can cross.
Old 05-11-2007, 04:35 PM
Dieseldude4x4's Avatar
If you find the right one, let me know. Mine has not been changed since Keith put it on there over three years ago.
Old 05-11-2007, 07:05 PM
The right one is any filter that fits and is 10 or lower, the lower the better.
Old 05-14-2007, 07:20 AM
6WHEELER's Avatar
Dieseldude4X4,
I have been using the HF6604 which according to Geno's is a 3micron.
The Donaldson cross is P169392 which according to there website is a 5micron
Donaldson Hydraulic Filters Product Attributes
A - OD (Inches): 3.72
B - Thread Size (Inches): 1 1/2-16
C - Length (Inches): 8.02
D - Gasket OD (Inches): 3.45
E - Gasket ID (Inches): 2.97
Product Type Description: HYDRAULIC SPIN-ON
Primary Application: PALL HC7400SUP8H, HC7400SUN8H
Media Type: Synthetic
Efficiency Beta 75 (Micron): 3
Application Note: SYNTEQ Media #2
Old 05-15-2007, 11:33 AM
Cool, guess I need to go on there and order one. Do you drain the water separator on any periodic basis?
Old 05-15-2007, 11:49 AM
Diesel-Dan's Avatar
Drain as much as you feel you need to. Its a good habit and if you want to get picky...i think its actually recommended that you draining the stock WS every time you fill up......Might be a bit excessive....BUT it only takes one tank of fuel. I would carry a glass jar to drain into. That way you can inspect for water and no pollute....even though the fuel pumps have years worth of diesel around them on the gnd already! hahah....
Old 05-15-2007, 02:33 PM
6WHEELER's Avatar
I drain it when ever I remember to, I beleave it is suppose to be done after the truck sits over night, can't remember where i hear that, but I usually do it in the morning before I start her up."When i remember that is"
EverydayDiesel
11-30-2007 09:11 AM
ollie32
06-03-2007 09:29 PM
storx
17
06-29-2006 01:33 PM
PowerDually
0
04-26-2006 04:23 AM
Mike S
12-03-2004 07:14 PM
Quick Reply: Fass replacement filter question
