fass question
Old 08-05-2008, 07:00 PM
olbetsy98_12V's Avatar
Question fass question
I have a 98 12v and i just bought a fass pump and i was wondering were you run the fuel line to? Do you have to run it to the stock lift pump like it says to or can you run it strait to the filter and bypass the lift pump?
Old 08-05-2008, 07:08 PM
Smokin Flatbed's Avatar
did you buy just the pump or the whole deal
Old 08-05-2008, 07:10 PM
i bought the whole kit
Old 08-05-2008, 07:15 PM
I have the 150/180 kit it came everything to delete everything off the side of the motor except the fuel pump block off plate(can source one for a chevy sb or bb at any parts house). Ran from the FASS to the inj pump, cut banjo off the inj return line t into factory return.
Old 08-05-2008, 07:19 PM
what kind of fuel pressure are you running at?
Old 08-05-2008, 07:22 PM
It is the 45psi kit(I need to get a gauge hooked up) so I dont have a definate answer.I know with the factory lift pump it would run out of fuel at 3000rpm now I have not found the top yet
BCarmicle
13
11-07-2005 04:20 PM
Buckshotmckee
05-23-2005 12:08 AM
2wheelsup
05-17-2005 10:45 PM
Flatty
04-25-2005 12:49 PM
ralphie
04-21-2005 12:51 PM
Quick Reply: fass question
