Fass kit
Hose
FL-1001 for 3/8"
FL-1002 for 1/2"
Both sold by the foot.
Wire Harness:
The one with the relay for 98.5-04.5 trucks -- WH-1002 (NOTE: you can get this harness to work with any application.)
The one without the relay for 94-98 and 05-07 Trucks -- WH-1001
Click here and check out page #6.....
That will give you every part used in a kit for your year truck. ALSO...for the fittings, RM-1002, bolts and such....use this mounting package part number:
MP-A9008
MP-A9008
So will this MP-A9008 turn it into a HPFP from a FASS.
From the parts list I think this is all I will need.
THB 1001
WH 1002
PL 1001
PL 1003
DIPF 1001
FF 5079
THB 1001
WH 1002
PL 1001
PL 1003
DIPF 1001
FF 5079
If you want the items for the HPFP, this is what you will need:
WH-1002
14' FL-1001
THB-1001
BHB-1001
MP-A9009
AND if you have the FASS...you can get the HPFP base and convert it with a part numbers:
AB-1001
OR-031 (O-ring)
6120 (Gasket)
PS-1004 Spring (18 PSI)
This is the adapter base for the HPFP and items to make it work. BUT i would suggest just selling the FASS and using some of that money buying a new HPFP with full wnty and such......
BCarmicle
13
11-07-2005 04:20 PM
Buckshotmckee
05-23-2005 12:08 AM
Flatty
04-25-2005 12:49 PM
