FASS DDRP Installed!
Old 12-11-2008, 08:20 PM
leeboy's Avatar
Just put on the Fass DDRP and wow, what a difference. Truck idles at 18 psi and under throttle never went below 14psi. I used Fass's banjo bolt replacement kit, very easy to do. Thanks Eric at Vulcan and Dan from Fass......
Old 12-11-2008, 11:23 PM
dodge_24's Avatar
do u have to use the banjo bolt replacement kit or does it come with everything to install
can u use the factory fuel lines
thanks
Old 12-12-2008, 07:07 AM
JAX
JAX's Avatar
The kit comes with everything you need.
Old 12-12-2008, 08:35 AM
Diesel-Dan's Avatar
Should come with everything needed for 2000+ Trucks....for the 98.5-99's, you will need to modify the factory line with a rubber splice or install one of our BBRK-1001 kits. We have been addressing these on a case per case, with our dealers.
Glad its working out for you Lee...should have thoes screens here very soon.
dahla
03-02-2009 06:10 PM
mrock
13
01-17-2009 02:02 PM
mrock
01-05-2009 09:10 PM
Desperado
15
12-09-2008 10:59 AM
dodge_24
10-18-2008 05:43 AM
Quick Reply: FASS DDRP Installed!
