fass and walbro
Old 08-19-2007, 08:43 PM
emoryemt-i's Avatar
fass and walbro
ok i am fixing to get a new fp setup. i have looked at both the fass and the walbro and dont know what the differences are. i have a budget of around 450 so if you guys can give me some advice that would be great. i have to go to florida in 3 weeks so i want to go ahead and get one on here so i can keep it to the floor and not have to worry about fp issues. right now on the stock pump i idle around 14 and it drops to 5 wot.
Old 08-19-2007, 09:24 PM
crobtex's Avatar
I've had my FASS, HPFP on for a little over two years, and it has worked great. Idle at 19, cruise at 18, and cannot pull it below 16 with my current setup. Also, the install is pretty easy and straight foreward.
Old 08-19-2007, 09:29 PM
emoryemt-i's Avatar
Re: FAss
how hard was it to install and what kind of maintenance if any have you had to do.
Old 08-19-2007, 09:34 PM
chrleb1's Avatar
If your budget is $450, then go with the Walbro. You'll have money left over.
Old 08-19-2007, 09:42 PM
RowJ's Avatar
Ditto~ I have the full FASS...150/150/1008..... for almost 4 yrs. Never below 17 psi at WOT.
Only maintenance is changing the fuel filter @ 50,000 miles.
Send me your e-mail address if you want a side by side comparison of the components. Both systems work well but the FASS, or the HPFP, are high quality and over engineered....just the way I like important systems.
RJ
Old 08-19-2007, 09:53 PM
crobtex's Avatar
You can get an HPFP for less than $450. Check http://www.mwfi.com/FASS/FASS_Diesel_Filters.html as a pricing example. I have nothing to do with this company, just showing the pricing.
Old 08-19-2007, 10:08 PM
crobtex's Avatar
Not a hard install. The only "speciality" tool I could have used was an angle drill. I'm pretty sure the new kits have everything you need except the tools.
Old 08-20-2007, 12:41 AM
Russ Roth's Avatar
They do have everything. Except the tools of course. Just put one on my buddies rig yesterday. I intend to replace my Walbro with one eventually.
Old 08-20-2007, 12:57 AM
PourinDiesel's Avatar
Get the fass.
Old 08-20-2007, 07:27 AM
emoryemt-i's Avatar
Re: FAss
what is the benefit gained by repalcing the walbro with the fass arent they about the same thing. why is the fass so much better. and thanks for the link to mwfi
Old 08-20-2007, 08:42 AM
Russ Roth's Avatar
Not the same at all. The FASS is all metal and much better built. It is also a different style of pump. Walbro will not take hardly any crud at all in the fuel without ruining them because of the plastic innards.
Old 08-20-2007, 09:03 AM
97' CTD's Avatar
I went with the FASS 150/150
Brandon
Old 08-20-2007, 12:53 PM
emoryemt-i's Avatar
more fass and walbro questions
are these fass the ones with the filter system on them or just the fp itself and is anyone having trouble with the walbro
Old 08-20-2007, 02:10 PM
Diesel-Dan's Avatar
HPFP=
FASS=
4RnrRick
17
03-25-2007 12:23 AM
the_fox_man4
13
12-26-2006 02:10 PM
sumner
77
11-13-2006 08:16 PM
tristan21
15
04-17-2006 09:04 PM
Quick Reply: fass and walbro
