Fargo won't pull
Old 05-15-2008, 12:47 AM
Whistler477's Avatar
Fargo won't pull
I have an '03 2500 4x4 auto. When it's at 2300-2500rpm, under load, turbo seems to dump pressure, & the truck just dies. There is a large puff of white smoke, & it won't do nothing until I back out of it, then it rattles like a bastard, coughs out black smoke, sometimes backfires, then runs fine until it hits 2300ish revs again. Its bringing up code 0521 ( oil sensor rationality, whatever that is.) Any insight to this would be great.
Old 05-15-2008, 06:13 AM
Hounddog's Avatar
Sounds like running out of fuel. Lift pump? Fuel filter? Water in fuel?
Old 05-15-2008, 03:56 PM
Mr Bee's Avatar
Hounddog is correct, and I might add that because it happens at the higher RPM, you may want to look for a restriction, pinched fuel Line, bad/old filter as well.
Old 05-15-2008, 07:00 PM
It was the fuel filter. I had just changed it probably 2000k ago. Never even thought of it. Thanks for the help guys.
Old 05-15-2008, 07:18 PM
Hounddog's Avatar
I take PayPal. I'd drain a few ounces each fillup for a few tanks and see what you get.I drain a few ounces on mine almost every tank.No one EVER says their water in fuel light came on.Never.
Old 05-15-2008, 08:07 PM
There wasn't any water in the filter bowl when I pulled the filter. But there was what looked like fine sand & metal filings in it. I cleaned it all up, but I think I'll check it again next tank. The old lady nearly ran it out of fuel a couple of weeks ago, thats probably where the sediment came from. The filings concern me though. Your check is in the mail, Houndog.
Old 05-15-2008, 08:16 PM
Spooler's Avatar
Filings could be from the Lift Pump (LP). Has it been changed over to the in tank LP?
Old 05-15-2008, 08:39 PM
The lift pump has been changed at the dealer. I'm not sure if it is in the tank. Whatever the recall update is, I got.
Old 05-15-2008, 08:59 PM
Spooler's Avatar
Yeap, it is the in tank conversion.
Old 05-16-2008, 03:42 AM
Hounddog's Avatar
Filings could be from the CP3
Old 05-16-2008, 04:59 PM
Spooler's Avatar
Yeap, I have personally seen that before with a stock truck at the dealer while having my company truck serviced. Hope not for his sake.
94ram
Competition / Pulls / OffRoad
09-14-2009 02:33 PM
Purplezr2
02-10-2009 08:18 PM
RamSST
Off Road / 4x4
10-18-2008 12:13 AM
Homestead
05-31-2004 03:19 PM
Quick Reply: Fargo won't pull
