Factory Dodge tow mirrors 2nd gen???
Old 03-30-2010, 08:30 AM
J OOPS's Avatar
I have an 02 and I thought I had seen factory Dodge Ram mirrors that would manually pull out for towing. Have you guys seen the mirrors that I'm talking about, and who makes them?
Jim
Old 03-30-2010, 09:11 AM
rebal's Avatar
factory mirrors dont pull out they flip up and out ,you can find after markets on the E bay
Old 03-30-2010, 09:31 AM
JKM
JKM's Avatar
the ones that pull out are ****'s , they are aftermarket ( and ugly as a steam powered wrist watch if you ask me)
http://www.cipausa.com/extendable.htm
Then there are these : ( bottom of page 6)
http://www.kool-vue.com/lookup_detai...0&id=2000&pg=1
Old 03-30-2010, 11:44 AM
J OOPS's Avatar
Must have imagined it. Might have been a different make. I agree with JKM ****'s and I think Kool-Vue both look like ****
Old 03-31-2010, 08:54 AM
urbs1391's Avatar
I know I'm off topic, but are you a kawie rider?
Old 03-31-2010, 10:11 AM
JKM
JKM's Avatar
Yup. why?
Old 03-31-2010, 11:39 AM
urbs1391's Avatar
I thought I'd remember you from there..... You got a distinctive avatar.... Just got another expensive toy, and it matches my KFX also......
Old 04-10-2010, 08:50 PM
traverler48's Avatar
go here--http://elektro.cmhnet.org/dodge/mirrors/
Old 04-20-2010, 11:42 PM
first4age's Avatar
I have the Kool-Vue and I really like the setup. It looks OEM, flip out when I need it, and is powered so adjusting them isn't a PITA.
Old 04-22-2010, 02:45 PM
Canuckville's Avatar
Hi Jim
Have a look at the write up I did installing the Kool-Vue's on my truck.
https://www.dieseltruckresource.com/....html?t=254174
Old 04-22-2010, 03:56 PM
650HP-CTD's Avatar
Jim
You can order OEM replacement towing mirror that swing up into place for towing. The aftermarket mirrors that swing out are junk IMHO. They vibrate and shake at freeway speeds making it hard to see.
Here is the OEM Mopar part number....note, these are NOT power mirrors as Mopar doesn't make them, just this manual version, so if you have power mirrors....you won't after you install these:
1 - 82206157
I got mine for around $325 through a local dealership.
--Sk
Old 04-22-2010, 04:26 PM
trainermg's Avatar
mine that i have slide over the mirrios that on my truck>
Old 04-24-2010, 12:39 PM
SIXSLUG's Avatar
I've got the kool-vues and they are good, they don't shake unless I'm going over 70 into a headwind and they are power and heated. THey fit perfectly and are very effective when flipped out. You will need to get the backer plates if you do not already have the Dodge manual flip outs, the control switch and a heater buttoned A/C control panel. If your truck is an SLT or Laramie Plus its probably already got all the wiring and connectors in it.
If they are shaking, get your tires balanced!
Justin erler
08-25-2011 03:23 PM
IanM
01-16-2011 03:15 PM
casper_cobra
04-14-2006 11:32 AM
FRANKV469
03-07-2004 10:18 AM
Quick Reply: Factory Dodge tow mirrors 2nd gen???
