dcwm
03-02-2008, 04:25 AM
I used to have an 01 Dodge but sold it because of big payment yada yada yada...
I loved that truck and the way the Cummins would start up in the winter time.
I now have a Ford F-350 4WD PSD. I kind of like the PSD, the way it sounds, lots of power and the fuel econ isn't that bad, the problem is winter starting. The glow plugs and using crankcase oil to fire the injectors is (in my opinion) a recipe for a hard starting engine when it's below 20 degrees. I know guys that say they have no problem but by golly I need to know my truck is going to start.
Enter the Cummins conversion. I've been gathering info to see if it's something I want to tackle both financialy and physically ( I have the mechanical know how) I'm just getting old and sore all the time etc etc.
If I were to find a doner truck say 94-95 vintage there's a few questions that come to mind that I haven't read anywhere.
-Will these conversions kits allow one to bolt the foreign engine into the Ford without much or any fabrication?
-Is there enough room lenght wise for the intercooler or does the grill/front end need to be modified?
-How do you work out things like the cruise control and everything else the PCM runs?, these trucks are like the star ship enterprise where as it's run by a computer.
-*Edit* I almost forgot, what about transmission? It looks like the main shaft will be short by adding 1/2" or so using the adapter plate. Will the spline fully engage the clutch and pilot?
Like I said I really like the Ford truck just not so crazy about what makes it go huden huden.
Thanks a million Guys.
Don
Don
