EZ Stacking question
I am of coarse wanting to always add a little more but wanted to know before I do it, I currently run my EZ on setting #2 because I am stacking it with the TST and worry about the higher settings advancing the timing to much or run the rail pressure to high, so would it be safe to run the EZ on setting #4 while stacked??? Thanks for any input, Mike
cquestad,
Yes, it makes a difference. The TST goes into the block, EZ into the TST, and the stock pigtail into the EZ. If you reverse it you won't get over ~22 psi boost and it'll be down on power.
John
John
Originally posted by banshee
I run mine on level 4 and haven't had a problem yet.....
John
John
Mike,
I still have the old software . Only the EZ plugs into the fuel rail pressure sensor, so just do that one the regular way. The only common plug is the MAP sensor, so just be sure the TST is first there. When I first stacked mine it ran terrible and set a code, but I found that a pin had pulled out of the EZ MAP harness plug, so you might check those if you have problems.
John
John
Mike,
John
Mike,
John
acook
07-30-2006 03:17 PM
99 cummins
01-29-2006 10:34 PM
gdh11
10-21-2004 05:11 AM
Sarge1124
02-18-2004 06:44 PM
