EZ Settings
Old 11-13-2003, 03:01 PM
TurboPirate24v's Avatar
EZ Settings
I have a BD Edge EZ and I don't think I can change the settings....but, I hear people talk about being able to change a jumper to get different behavior.
Am I missing something ? Should I look closer ?
Do all Edge EZs have multiple setting capabilities ?
Old 11-13-2003, 03:23 PM
Re:EZ Settings
Nevermind...I just was on the Edge web site and found the instructions about removing the cover and this is where the jumpers are...I didn't read the instructions very well... :
I presume mine is set to 3 ( Default )...
I have no other fueling mods...
So...what difference will 2 and 1 make...?
Of course...I expect CONS but any PROS ???
Old 11-13-2003, 03:27 PM
AlpineRAM's Avatar
Re:EZ Settings
The Edge EZ has a jumper that can be set to 3 positions.
The jumper determines the low boos fueling of the box.
Installation and setup instructions for the EZ can be found here:
http://www.edgeproductsinc.com/images/Power Edge EZ Cover-Install.pdf
HTH
AlpineRAM
Edit- You posted while I typed ;D
Cons of setting the jumper to lower responsiveness.- more lag less off the line kick.
Pros- some people like it better with a lower setting for the reduced smoke on takeoff and better throttle control- also it will be less suicidal to do a kickdown on the automatic tranny trucks with the Edge on a lower response setting
Dieselhead
05-01-2003 04:05 PM
70crewcab
03-03-2003 09:10 AM
hotdram
02-18-2003 06:41 PM
danlit
22
02-07-2003 07:45 PM
Quick Reply: EZ Settings
