ez secret level
Old 12-21-2004, 02:29 AM
lt11le's Avatar
ez secret level
just wanted to ask you guys if there are any other levels inside the ez for the 2004.5 600.
Old 12-21-2004, 12:21 PM
Patriot_RAM's Avatar
There is for the 2003/2004. If settings 1-4 are the same, maybe the hidden level 5 is the same also. You'll know it if it's right. On the 2003/2004 it's 10 additional hp over level 4.
Old 12-21-2004, 01:03 PM
DTR Advertiser
Don M's Avatar
Dont use it if you find it.
Don~
Old 12-22-2004, 06:15 PM
502502's Avatar
Don~
DON:
Not to get off subject, but what setting would you use with a TST stacked?
Of course I know I will need to turn down the TST to make similair power levels
(I just bought a used EZ for $275, and plan on stacking for the ride home tonight)
Old 12-23-2004, 11:40 AM
WhiteSport600's Avatar
I just swapped an EZ onto mine last night and took the BDDL out. It runs good on all settings w/no popping anymore on the higher settings. It seems to like 7/3 the best for power.
Old 12-23-2004, 12:08 PM
BEHRMAN's Avatar
Don~
Can I ask why?
Old 12-23-2004, 04:18 PM
doug's Avatar
Here's why *I* wouldn't do it. Quite simply, it raises rail pressure to high. There is compelling data which emperically suggests that level 6 and the other 90+ pressure boxes probably bump the pressure relief valve. On my truck the on board pressure sender won't even report pressures higher than 26,100 PSI, and thats about 40 RWHP (from pressure fooling)
Old 12-23-2004, 04:20 PM
doug's Avatar
good job! have you or anyone else measured how much timing advance the TST/bullydog combination provides? The TST's analog time fooling and duration extension just seems like a really bad combination (to me) with the Bullydog downloader.
Old 12-23-2004, 04:21 PM
BPD239's Avatar
Is the Edge EZ for the 4.5 equiped with the jumpers, or the in cab switch? I thought that I saw that the EZ had a toggle switch to change the settings.
Old 12-23-2004, 04:26 PM
doug's Avatar
in cab switch for the 04.5s
Old 12-23-2004, 10:22 PM
Big Bob's Avatar
I am no expert, however, I have never heard of an EZ having a in-cab switch. Edge's web page doesn't show or talk about any in-cab adjustments for the 04.5-05 EZ. The information on the Edge site states that the EZ mounts under the hood.
I could be wrong.
Not only that, WhiteSport600 stated, if I read it right, that he liked the EZ on 7/3 best. I've never heard of these settings on an EZ. Did Edge completely redesign the 600 EZ and not upgrade their website.
Old 12-23-2004, 10:55 PM
Big Bob's Avatar
WhiteSport600,
After reading your signature, I think I just figured out what you are talking about with the 7/3, You are talking about the TST settings, right? You didn't mention the TST in your post and I thought your were talking about a 7/3 setting on the EZ.
Old 12-24-2004, 08:23 AM
BPD239's Avatar
I'm not 100% sure if its in cab adjustable or not. I've been searching hard to figure out what box I am going to buy and one of the features I've been looking for is the ability to change the settings and turn it off. This is where I found the adjustable feature on the EZ.
http://www.dieselperformanceparts.com/cgi-bin/search.pl/dieselshop?f_success=dieselshop2&e_unique=EZD1000
Maybe Mark@DPPI can let us know if this true.
Old 12-24-2004, 10:18 AM
doug's Avatar
look at the picture in BPD239's post. there you see the wire with the switch on the end.
Old 12-24-2004, 11:34 AM
Jeff K's Avatar
Yes, the EZ for the 600 has a 3 position switch for in cab adjustment.
Quick Reply: ez secret level
