exhaust brake install
Old Jun 26, 2007 | 09:28 PM
macjazzy's Avatar
I am installing a Bd exhuast brake into a friends 01.5 ho. I seem to remember seeing on here in the past that there is wire I need to buy to install into the pcm to utilize the trucks control of the brake. Where can I get that little wire to install in the pcm connector and which position on the connector is it? Or am I completely wrong about all of this.
Old Jun 26, 2007 | 10:07 PM
ellerman's Avatar
I bought me Jacobs e brake used and I got the proper wire to go to the ECM from my local Cummins dealer. Eric
Old Jun 26, 2007 | 10:11 PM
J Lent's Avatar
It is a clip/tab that goes into the ecm harness plug & makes contact. I never wire them in like that because the ecm will delay engagement of the brake for 3 seconds before it engages or disengages. I use a Pacbrake pedal switch which engages the brake when the throttle pedal is released. They engage immediately. The complete system on/off control is mounted on my gear shifter [stalk switch].
Old Jun 27, 2007 | 06:12 AM
macjazzy's Avatar
Can anyone tell me where the wire goes? Or a part number for it?
RockysInMyBlood
Nov 18, 2007 02:35 AM
DCinTX
Mar 18, 2007 11:00 PM
