how exactly does the torque lockup switch work??
Old Dec 12, 2002 | 11:54 AM
midwestdually's Avatar
anybody know??
Old Dec 12, 2002 | 12:54 PM
TPilaske's Avatar
Re:how exactly does the torque lockup switch work??
Call Bill at DTT, or check out there forum! ;D<br><br>Tony
Old Dec 12, 2002 | 01:57 PM
AlpineRAM's Avatar
Lockup switch operation:<br><br>The PCM locks up the TC by grounding a wire of the lockup solenoid. Basically there is one relay in the PDC that &quot;arms &quot; the lockup solenoid valve by putting voltage to the valve when you are in OD and are in the right range of throttle, and the line from the solenoid valve that is grounded when the PCM says lockup. <br>So the lockup switch does the following: First you replace the relay with a bridge, so you can lockup in 2, 3 and od <br>Second you splice into the cable to the pcm, and ground it thropugh a switch. <br>Visit tstproduct lockup switch for some more info.<br>But be aware that this thing is no cure for tranny problems and should be used very carefully to avoid damaging drivetrain components!<br>( My personal opinion is that it's a good idea to call Bill K at DTT, but I am biased )<br><br>AlpineRAM
cowboykilla235
Feb 17, 2013 03:02 PM
93dieselZak
Jun 16, 2011 06:10 PM
sallyman1
49
May 14, 2008 11:31 AM
RDR
Dec 24, 2007 07:37 PM
04ctd
Sep 4, 2006 03:18 PM
