Ever Seen One of These?
Old 01-15-2010, 01:18 PM
M1Lover's Avatar
I have.... Any idea why this would happen?
Old 01-15-2010, 01:23 PM
Rick 12v CTD's Avatar
You bought it like that or? so weird...
Old 01-15-2010, 01:25 PM
M1Lover's Avatar
No, the box is from the new REPLACEMENT for the one that cratered on Cyl. 6
Old 01-15-2010, 01:29 PM
was the pushrod bent? it looks like some serious mushrooming right where it came apart. Just seems weird that it would come apart like that.
Maybe some sort of defect, who knows. I certainly can't give any reasonable input on why it did that.
Old 01-15-2010, 02:07 PM
JD730's Avatar
Yes, saw that happen once, don't know why it did it, but I know my buddy bought the truck real cheap because no one bothered to pull valve covers and diagnose it.
Old 01-15-2010, 02:33 PM
jimbo486's Avatar
valve adjusted too tight? or the valve dropped and the piston shoved it back up?
Old 01-15-2010, 03:23 PM
ghenges's Avatar
Appears to a bad factory weld because there is very little weld bead on the end piece. Looks like there was slight weld penetration on the end piece.
The weld, if good, should have tore metal out off the end piece when it separated.
Old 01-15-2010, 03:42 PM
M1Lover's Avatar
Mushrooming happened after it came apart.
Old 01-15-2010, 04:11 PM
Wow, sorry about your luck.
your having alot of problems with your LOW mileage truck that most of us don't see until 500,000
Did you have to get your head gasket replaced ?
Old 01-15-2010, 06:27 PM
that's kind of what I thought but wasn't sure.
Old 01-15-2010, 07:07 PM
dngurney's Avatar
how good is oiling to top end looks like it saw alot of heat
Old 01-15-2010, 09:00 PM
M1Lover's Avatar
That's from the electro-weld process when they're made....
Old 01-17-2010, 03:07 PM
I'm with him. The only other cause I can think of is running with too much lash for a long time, but I'd expect other stuff to look really beat up too.
swank
06-17-2009 06:57 PM
singleturnout
02-21-2006 12:42 AM
spunbearing
04-04-2005 08:04 PM
Mark Thomas
03-05-2005 09:11 PM
chuck3
10-19-2002 05:32 PM
Quick Reply: Ever Seen One of These?
