will it ever end with this truck?
Old 01-21-2008, 11:55 PM
bullboy85's Avatar
ok all the boost leaks are fixed, still only got arond 22 psi, though this time would build boost all the way through the rpms maybe a 1 or 2 psi drop off at the end. so whats next to look at, dying vp? dying turbo? bad injectors? any ideas? this is getting old
Old 01-22-2008, 05:26 AM
AlpineRAM's Avatar
Let's see- I hope that this helps:
I'm not familiar with the XZT+ , does it have EGT defueling? Maybe set too low?
I'd start with checking the boost gauge- just use regulated shop air to verify that it works.(Had some fun with a kinked line that made mine read very low)
What are your EGTs? If they are low it ain't enough fuel. This would lead to checking connectors, box settings etc.
If they get above 1300 and you have smoke when at your max boost you lack some air. This would make me check the air filter, turbo shaft play, boost leaks (There may still be some, did you check with a pressurized intake, I'd suggest going up to 35 psi) and also valve clearance.
Naturally the VP44 can be weak, the injectors could be bad (unlikely) or a mis-wiring or defect of your box. (Like it doesn't boos fool the ECM and therefore defueling occurs.
Just my 2c
AlpineRAM
Old 01-22-2008, 06:22 AM
Valv's Avatar
I tried a boost elbow once and could not get more than 24lbs. I really had to crank down the screw well shut before finally have some pressure.
I even added some teflon tape to it to seal better.
Get something to squeeze the wastegate hose shut completely and see if boost climbs.
Old 01-22-2008, 09:20 AM
bullboy85's Avatar
well, i wasnt sure my apparatous would support 35 psi sence it failed onece at 5 psi, ill try and strap it down tighter and get it as high as i can, ill pinch that line off and see if it does anything, my exost is post turbo thats y i hadnt put any numbers up, ill look agen i think its only getting to 800*, this is the second box, the first didnt load tunes right... checked for play in the turbo found none. ill try those things first chance i get and get back to you, o and yes i did pressurize the intake
Josh1979
16
11-07-2011 01:35 PM
sluggo42
08-02-2011 10:12 AM
19Fury69
ABDTR #5
97
03-18-2009 09:00 PM
mhuppertz
02-05-2008 05:08 PM
mo.redneck
10-03-2006 08:30 PM
Quick Reply: will it ever end with this truck?
