Engine won't crank
Old 09-11-2005, 01:43 AM
CTD99's Avatar
Engine won't crank
Ok, I got everything back together... I think. Turn the key but not much happened...no cranking. The lift pump sounds very weak but I'm thinking that is just air in the lines.
Also, when I first turned the key on I rolled the windows down... but now they won't go back up. So I don't know what's going on... but it's late, I'm tired, and whatever it is can wait 'til morning.
Any ideas on where to start looking?
~ Russ
Old 09-11-2005, 02:08 AM
Haulin_in_Dixie's Avatar
~ Russ
Weak batteries or bad grounds. Check where the box feed goes to the drivers side battery, its been sitting maybe lost contenuity.
Old 09-11-2005, 11:30 AM
CTD99's Avatar
Batteries are new and I cleaned/sanded all the grounds before hooking them up.
Old 09-11-2005, 12:04 PM
John Faughn's Avatar
crank
try using jumper cables , jumping the ground side 1st ,from battery to starter body , try key ,if no responce then jumper wire at solinoid ing. wire to batt. +, if no responce then jumper cable batt.+to cable on solinoid try key , if still no responce then start over ,load test batteries .
Old 09-11-2005, 04:07 PM
CTD99's Avatar
My brother pointed out a blown fuse... just needed a fresh set of eyes.
Old 09-11-2005, 04:09 PM
Geico266's Avatar
Happens to all of us, we're here when you need us.
Old 09-11-2005, 07:21 PM
Glad you found it....
ado2b1
12-16-2008 03:19 PM
Jake_E
12-07-2008 09:22 PM
Machinos
03-16-2008 01:34 AM
aaronedwards82
01-14-2007 09:07 AM
PaulDaisy
12-02-2006 12:36 PM
Quick Reply: Engine won't crank
