engine warm-up with exhaust brake
Old 11-04-2003, 09:55 PM
fishin fever's Avatar
Hi all :I'm new to the ctd world and lovin it/ ;D I've read that some use their : ex brake to speed up cold start warm ups .why does this work ?what is a safe time? are there any drawbacks....see sig for truck info thanks ???
Old 11-04-2003, 10:51 PM
sixpack47's Avatar
Re:engine warm-up with exhaust brake
Use mine all the time for warm up! ;D The brake will create a small load on the engine to keep combustion temps up (see tsb 18-31-1 cold idleing). I let mine run with the brake on until temp is up to normal range. The only draw back if you want to call it that is, you have to clean your IAT sensor on a regular basis due to the back pressure of the e-brake. Phil
Old 11-05-2003, 08:31 AM
rattle_rattle's Avatar
[quote author=sixpack47 link=board=7;threadid=22019;start=0#msg205881 date=1068007915]
[/quote]
Give me a little more info on this cleaning of the IAT sensor. I've never cleaned mine and use the PacBrake to warm her up all the time.
Old 11-05-2003, 08:51 AM
Dr. Evil's Avatar
[quote author=rattle_rattle link=board=7;threadid=22019;start=0#msg205988 date=1068042683]
[/quote]
[/quote]
The following link will tell you just about everything u need to know about the IAT sensor....
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
Old 11-06-2003, 10:16 AM
[quote author=Dr. Evil link=board=7;threadid=22019;start=0#msg205993 date=1068043888]
[/quote]
[/quote]
[/quote]
Thanks! Great article!
mtb1982
55
01-20-2020 10:45 AM
klx650a2
07-22-2008 06:47 PM
herb
07-18-2008 08:25 AM
2500TurboDodge
06-28-2005 09:52 PM
dma251
06-07-2003 02:28 AM
Quick Reply: engine warm-up with exhaust brake
