Engine warm, hard start
Old 08-29-2009, 11:09 AM
Roadmedic's Avatar
My friend has a 2006 5.9 that has recently started having problems when the engine is warm or hot.
He turns off the truck and it does not want to start. Runs the battery down. Put on the jumper cables and it fires right off.
Changed to new batteries, still has the same problem.
When it will not start, if on a hill, just lets it go and dumps clutch and it runs.
The only code is referring to low voltage.
It starts right off when the engine is cold.
Old 08-29-2009, 12:21 PM
CUM4X4MINS's Avatar
So he ends up cranking it so much that it drains the batteries? When mine is hot and I don't let the grid heater cut off first before trying to start then it cranks for a few seconds longer before it lights off.
Michael
Old 08-29-2009, 05:03 PM
Roadmedic's Avatar
He tries to start it, but after a few attempts, the system just does not have the juice to start.
I know a guy that had the same problem with a ford 7.3. He used to pour water down the valley to cool it and it would start.
It just baffles me. I think there might be a sensor or something that is weak on the starter circuit.
Old 08-29-2009, 08:16 PM
CUM4X4MINS's Avatar
**** thats weird. Does it still die down and not have enough to start it with the new batteries? If so then something has to be drawing off some of his charge some where. I have watched my step father sit there and crank on his old 7.3 for almost an half hour in the winter before it would fire off. Something is up. Wish I could be more help but I don't have it in front of me to diagnose.
Michael
Old 08-29-2009, 08:36 PM
WhiteMule's Avatar
I would be looking at battery cables. May be breaking down with heat.
Old 08-29-2009, 09:26 PM
Roadmedic's Avatar
Michael
It happened at the dealer. They had the scanner on it and it was not showing anything but low battery voltage.
Old 08-29-2009, 09:58 PM
Roadmedic's Avatar
What would be a sign here?
That is a thought.
Old 08-30-2009, 12:49 PM
CUM4X4MINS's Avatar
That is a thought.
Yeah would check resistance in the cables on his truck then the cables on another truck.
Michael
Old 08-30-2009, 07:38 PM
Roadmedic's Avatar
Thought of another potential source.
He had the fuel pump changed just before this problem started.
Old 08-31-2009, 01:27 PM
CUM4X4MINS's Avatar
Yeah could possibly be bad from factory.
Let us know what it ends up being.
Michael
Old 08-31-2009, 08:32 PM
Roadmedic's Avatar
Found out today, he needed new injectors. Got all 6 done. Says it solved the problem. Was pumping out too much fuel.
Old 08-31-2009, 08:38 PM
CUM4X4MINS's Avatar
Wow really. Well good to hear he got it fixed.
Michael
Old 08-31-2009, 09:38 PM
Roadmedic's Avatar
It was expensive. He has 380,000 miles on them.
mtb1982
55
01-20-2020 10:45 AM
bboukari
09-10-2005 09:17 AM
FamilyDiesel
03-24-2005 07:12 PM
gaRam
16
05-08-2004 11:09 AM
Quick Reply: Engine warm, hard start
